Author Topic: Cold Cathode ?  (Read 2548 times)
aj6500
  • Last login:July 29, 2003, 06:17:31 am
  • Does this rash look contagious?
Cold Cathode ?
« on: April 08, 2003, 02:39:53 am »
Is a cold cathode tube (about 15") bright enough to use for exterior cabinet lighting?  I've seen some that will flash with music, and I'm considering adding a couple to my jukebox.  If they are real dim, I won't bother.
Also I found a site that sold them REAL cheap, like $2-3 a tube.  I didn't bookmark as I figured I could find it again later.  Of course I don't get around to it for a couple weeks... so.  Anyone have a good source?
They say patience is a virtue, and ignorance is bliss.  So I guess you can have a pretty good life if you're stupid and don't mind waiting around.
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
Re:Cold Cathode ?
« Reply #1 on: April 08, 2003, 09:29:06 am »
I'm thinking of adding 2 of the sound-sensitive fixtures.. putting one of the sensors in the marquee where the regular speakers are and one down in the bottom where my sub's at.. hopefully there'd be enough difference to flash em differently
I just google'd on sound sensitive lighting to find some sellers and then used the part numbers either to google again or look on ebay
