Author Topic: MaLa has no sound now? *** FIXED ***  (Read 3200 times)
Encryptor
  • Trade Count: (+34)
« on: February 25, 2007, 07:35:02 am »
Ok a quick run down of what I did.
1. Got MaLa setup and running great! Love it!
2. Wanted Hi Scores back.
3. Looked and found documentation on how to put hi scores back.
4. Saved a copy of all old files in separate folder.
5. Re-compiled mame with hi score.diff file.
6. Mame didn't work after recompiling.
7. Copied backed up files back to mame folder after deleting new files.
Now I have no sound in MaLa. The sound still works fine if I play games in MameWah which I still have installed.
Any suggestions? I've looked in ini files for anything but haven't found anything helpful yet.
Encryptor
« Last Edit: February 27, 2007, 03:04:48 pm by Encryptor »
loadman
  • Moderator
    • MaLa
Re: MaLa has no sound now?
« Reply #1 on: February 25, 2007, 03:56:22 pm »
I would eliminate a few things:
Set-up another MaLa (basic) with another version of mame in a seperate folder.  Just a couple of roms and mame. That should only take you 5 mins
That will at least tell you if your other set-up has a problem or it is a bigger issue.
Then we can go from there...
Encryptor
« Reply #2 on: February 25, 2007, 05:45:18 pm »
Thanks for your help. I got it working again. I deleted it and reinstalled it. Now the sound works. I don't know what happened to it. Thanks again.
Encryptor
