Author Topic: MaLa help - Mame32 won't save game input changes from MaLa?  (Read 4049 times)
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« on: February 22, 2007, 02:30:03 pm »
Hi All,
I've got a strange problem with MaLa and Mame32 (.111) - If I start a game from the mame32 ui, and make input changes (remap controls), the <game>.cfg file is updated in the cfg folder. If I do the same when the game is launched from MaLa, the cfg file is not updated? I've checked the Mame Config / Folders options in MaLa and the "Game Configurations" folder is set to "cfg". I've also tried setting the value to the fully specified path, but it still does not work.
Has anyone else noticed this problem or have any suggestions?
Robots will kill you.
Arcade Addiction
arzoo
    • LEDBlinky
SOLVED: MaLa help - Mame32 won't save game input changes from MaLa?
« Reply #1 on: February 23, 2007, 09:10:15 pm »
Problem solved! I deleted and recreated my config (cfg) folder and now it works. I have no idea what the problem was.  :)
Arcade Addiction
loadman
  • Moderator
    • MaLa
Re: SOLVED: MaLa help - Mame32 won't save game input changes from MaLa?
« Reply #2 on: February 23, 2007, 10:19:06 pm »
