Author Topic: Connecting CRT computer monitor to JAMMA board  (Read 4565 times)
CICA2
  • Last login:July 16, 2007, 01:34:28 am
« on: February 19, 2007, 10:27:53 pm »
Does anyone know what is involved in connecting a CRT computer monitor to a JAMMA board?
Is is just a matter of connecting the red, green, blue, V sync, ground along with power to the monitor?
Or is there more to worry about?
VGA female connector Pinout:
1       Red out *
2       Green out *
3       Blue out *
4       Monitor ID 2 in
5       Ground
6       Red return
7       Green return
8       Blue return
9       no pin
10      Sync return
11      Monitor ID 0 in
12      Monitor ID 1 in
13      Horizonal Sync out
14      Vertical Sync out
15      reserved (monitor ID 3)
If this has been discussed a billion times, please direct me to an old one and my apologies for this post.
« Last Edit: February 19, 2007, 10:41:22 pm by CICA2 »
Ken Layton
  • Guru
  • Technician
Re: Connecting CRT computer monitor to JAMMA board
« Reply #1 on: February 20, 2007, 10:33:49 am »
98% of the JAMMA boards out there generate standard CGA resolution video not VGA. There are some that generate EGA (medium) resolution like Cruisin USA.
Here's a link to specific makes/models that can be used:
www.ionpool.net/arcade/tech/monitor_test_bench.pdf
Bleagh
  • Last login:October 18, 2016, 04:33:25 pm
    • BLEAGH!
« Reply #2 on: February 24, 2007, 05:30:11 am »
I have an arcade monitor with a vga connection connected to my Jamma boards.
I had to get a little pcb that would convert the signal, you can find them on ebay and from some dealers.  They can be a bit pricey.
