Author Topic: Do the Midway cabinets have 13/16" T-Molding or 3/4"?  (Read 1183 times)
paulkortne
  • Last login:May 24, 2003, 03:52:27 pm
« on: April 06, 2003, 09:27:19 pm »
I just measured the MK2 machine at my local arcade (which is an offical Midway cab), and I measured the T-Molding at 13/16".  Is this correct?  Is the wood also 13/16"?  I would prefer making everything 3/4", but I want to make it as close to the Midway design as possible.
OSCAR
    • Oscar Controls
Re:Do the Midway cabinets have 13/16" T-Molding or 3/4"?
« Reply #1 on: April 07, 2003, 09:45:23 pm »
Since you didn't get any replies yet, I'll take a stab at it.
I believe that the MK2 cabinet was made from 3/4" thick stock.  I am not aware of any construction sheets (plywood, particle board, MDF, or otherwise) that are available in a 13/16" thickness, but I could be wrong.  There are a number of woodworking gurus around here that confirm/deny this, though.  I don't *think* the original MK2 had laminated sides...
After 3/4" t-molding is pounded in the slot, it measures closer to 13/16" than 3/4", as I just checked on my cab.  Perhaps that is what you saw?
