Author Topic: CPViewer  (Read 5282 times)
greaser
  • Last login:December 21, 2007, 06:28:21 pm
CPViewer
« on: February 19, 2007, 02:18:26 pm »
I'm extrememly confused here. I'd like to use a program that displays what the buttons do in mame games (Fire,jump,punch,kick,etc). I guess Cpviewer is the program that can do this. Can anyone please tell me everything I'd need to get this working? I just don't understand it at all. I have the xml file somewhere that contains all the controls for just about every rom out there but what do I do next? Is there a tutorial somewhere or a configurator that can help me? I'd appreciate any help. I've tried to run cpviewer before and got nowhere. Very confusing. Thanks guys.
sphetr2
  • Last login:February 08, 2009, 06:35:00 pm
  • black and white album
Re: CPViewer
« Reply #1 on: February 19, 2007, 03:44:11 pm »
I'm interested in this as well. Will this work with MAME v.55 with GameLauncher? If not, will CPMaker or Johnny5?
needlesmcgirk
  • Last login:September 15, 2009, 10:54:31 pm
Re: CPViewer
« Reply #2 on: February 19, 2007, 03:54:11 pm »
http://www.cpviewer.emuchrist.org/
Go to the website and go to the downloads page.  There is documentation on how to do everything.  I haven't actually done it myself yet but I would like to do it sometime.
sphetr2
Re: CPViewer
« Reply #3 on: February 19, 2007, 09:00:24 pm »
I couldn't find a readme in the files. I'm also still afraid to do this because I'm not sure if it works with MAME v.55.
bfauska
Re: CPViewer
« Reply #4 on: February 20, 2007, 02:45:51 am »
I believe that this is the page with the documentation that was refered to earlier.  I havn't used any of it yet but this is where I am going to start my research.
http://www.cpviewer.emuchrist.org/screens.htm
hope this helps (for your sake and mine)
Later,
Brian
Aurich
  • Last login:September 12, 2021, 01:34:32 am
Re: CPViewer
« Reply #5 on: February 20, 2007, 01:12:53 pm »
I use it with Mala, it's easy. Just follow the instructions, it took all of 10 minutes to set up not counting my custom graphic.
sphetr2
Re: CPViewer
« Reply #6 on: February 20, 2007, 02:56:44 pm »
Later,
Brian
Thanks, found the pdf and I'm setting it up now.  8)
CCM
Re: CPViewer
« Reply #7 on: February 20, 2007, 03:36:33 pm »
Anyone else having problems with the CPviewer website?  I can't seem to get there...
Angry_Radish
  • Last login:October 24, 2020, 06:36:17 pm
Re: CPViewer
« Reply #8 on: February 21, 2007, 12:06:18 pm »
Works for me here...
I was using it for awhile in mala, but I had too many times where it would not clear when a button was pressed, or not come up at all and hang, and I ended up having to clear it manually..
When it worked, it worked great though!
greaser
Re: CPViewer
« Reply #9 on: February 25, 2007, 01:49:52 pm »
Still can't figure this thing out. Very confusing. Any more help/tips?
acevedor2
  • Last login:May 25, 2024, 08:21:24 pm
Re: CPViewer
« Reply #10 on: March 21, 2007, 04:22:45 pm »
I am trying to set this up and have followed the directions, but all I seem to get is some syntax error and it won't run.  I have followed the directions completely.  Any ideas?  I am going tot ry and ost the syntax error I get shortly.
Here is the picture.
« Last Edit: March 21, 2007, 05:07:09 pm by acevedor2 »
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
Dustin Mustangs
  • Last login:September 14, 2017, 11:43:18 am
  • Cut the sheet!
    • My Site
Re: CPViewer
« Reply #11 on: March 22, 2007, 08:57:33 am »
The developer of that program is a member here and I'm sure he could help you get it figured out.  You might have an easier time getting his attention with a post in the software forum or over at mameworld.
Aurich
Re: CPViewer
« Reply #12 on: March 22, 2007, 12:54:21 pm »
It's not going to work unless you have a front end sending it the proper string. What front end are you using?
acevedor2
Re: CPViewer
« Reply #13 on: March 22, 2007, 03:30:56 pm »
Mala Rc9
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
Re: CPViewer
« Reply #14 on: March 22, 2007, 03:39:44 pm »
I just downed and tried it in a dos window and it worked fine.
This plan is so perfect, it's retarded. -- Peter Family Guy
(+_+)
  • Let me splain.
Re: CPViewer
« Reply #15 on: March 22, 2007, 03:46:39 pm »
It has its own controls.ini file that contains the controller actions such as fire, jump, etc that it uses to populate the controller picture labels
greaser
Re: CPViewer
« Reply #16 on: March 22, 2007, 03:49:51 pm »
Well for starters I need to design my own control panel based off the one that's on my cab correct? Any tips on how to approach this?
Aurich
Re: CPViewer
« Reply #17 on: March 22, 2007, 05:40:10 pm »
Mala Rc9
Ok, for Mala you go to the Control Panel Viewer tab, and put in the path to your executable (C:\emulators\cpv2\CPV2.exe or whatever) then for the command line is should look like this:
-r=%rom% -c=%parent%
greaser: If you don't have Photoshops skills just take a picture with a digital camera of your joystick + buttons and use that. Personally I only show player 1 controls, it let's things be nice and big and clear, since 9 times out of 10 if it's a 2 player game the second player's controls are just the same.
acevedor2
Re: CPViewer
« Reply #18 on: March 22, 2007, 06:22:16 pm »
Thanks!  I'll give it a shot!
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: CPViewer
« Reply #19 on: March 22, 2007, 07:03:15 pm »
I know others have used this and J5 fine with MaLa.
When you get it running can you PM me what details you ended up using and I can update the Wiki on CP set-ups using mala..
acevedor2
Re: CPViewer
« Reply #20 on: March 22, 2007, 09:49:20 pm »
Ok, I added the command line as you said, and now I get this error:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
Aurich
Re: CPViewer
« Reply #21 on: March 22, 2007, 11:00:42 pm »
There should be a default mamelayout.lay file in your layouts folder, but it doesn't really matter since you need to make your own anyways. Now that you have Mala set up to call it you just need to follow the instructions in the docs folder.
acevedor2
Re: CPViewer
« Reply #22 on: March 23, 2007, 05:09:42 am »
I'll see if I can figure it out.  Problem is I have NO documentation for this in the MAME docs folder.  If extracting/executing  Mala/CPViewer was supposed to creat something in that folder, it didn't.  Additionally there is n o docs folder in Mala....
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
loadman
    • MaLa
Re: CPViewer
« Reply #23 on: March 23, 2007, 06:17:15 am »
Dude.. He means the CPViewer Docs.  :D
You have done all you need to do in MaLa and Mame.   ;D
You now need to set-up CPViewer according to your specific needs
Please read the CPViewer Docs .
 The link has been provided for you in earlier posts ;)  Hint: THE PDF AT THE BOTTOM
« Last Edit: March 23, 2007, 06:24:13 am by loadman »
acevedor2
Re: CPViewer
« Reply #24 on: March 23, 2007, 09:46:16 am »
Don't I feel like the idiot.  Talk about dense.  Thanks guys......I misunderstood.
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
loadman
    • MaLa
Re: CPViewer
« Reply #25 on: March 23, 2007, 04:21:13 pm »
Hey no doubt it was due to the excitement of your new Hobby..
Have Fun!  8)
acevedor2
Re: CPViewer
« Reply #26 on: March 23, 2007, 07:10:31 pm »
Absolutely!! :cheers:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
Re: CPViewer
« Reply #27 on: March 24, 2007, 07:00:00 pm »
Anybody have a preference for Johnny5 over CPVeiwer ? I myself am wondering which one to try.
Extreme8
  • Last login:August 24, 2008, 03:46:24 pm
Re: CPViewer
« Reply #28 on: March 24, 2007, 10:09:14 pm »
Try em both.
The price is right.
The hardest part is creating the graphic of your control panel, and that will work in either program.
