Author Topic: Save states are borked when MAME is upgraded.  (Read 3056 times)
Shoegazer
  • Last login:May 10, 2015, 10:37:58 am
    • NonMAME - The ultimate site for the OTHER arcade emulators!
« on: February 14, 2007, 02:31:24 pm »
I completely understand the rationale behind removing hiscore.dat, being that it was hacky to the point of intrusiveness.  I also understand how infinitely cooler it is to have an entire state saved for any given system, as the far better alternative.
What I don't understand is why I get the "Failed to load state" message for every game that supports save states, every time I upgrade MAME.  Is there something I'm doing wrong that causes this, or is the save state feature just not ready for prime time yet?  It's frustrating to get some pretty nice scores going on certain games like Galaga, only to have them completely zeroized with each new upgrade.
Not trying to whine here, honest - but at the risk of offending Aaron or anyone else who may be developing this feature - I just hope this is either user error or something to be addressed soon.  If the latter is true, I'll just increase my daily dose of patience and STFU.  ;)
Shoegazer
« Last Edit: February 14, 2007, 02:34:49 pm by Shoegazer »
NonMAME: Your best source for the OTHER arcade emulators!
http://nonmame.retrogames.com
FrizzleFried
    • Idaho Garagecade
Re: Save states feature is borked when MAME is upgraded.
« Reply #1 on: February 14, 2007, 02:34:36 pm »
You hit the reason why I stopped using savestates right on the head.   They are not compatible (for whatever reason) from version to version.  Screw that.  I just compile HISCORE.DAT support back in to Mame when I upgrade....
Havok
  • Trade Count: (+17)
« Reply #2 on: February 14, 2007, 02:40:27 pm »
Amen!
Savestate is the sux0r!
sewerrat
  • Last login:February 12, 2009, 11:53:11 am
« Reply #3 on: February 14, 2007, 07:11:58 pm »
Is there a "how-to" guide to be able to do this?
I cant seem to find one.
FrizzleFried
    • Idaho Garagecade
Re: Save states are borked when MAME is upgraded.
« Reply #4 on: February 14, 2007, 07:26:29 pm »
Download hiscore.txt here:  http://forum.arcadecontrols.com/index.php?topic=63130.0
Change the name to hiscore.diff.
Then go here and read how to compile.  It took me all of 20 minutes to figure out the first time and then another 30 minutes or so to compile....
http://www.mameworld.net/mrdo/compile.html
sewerrat
« Reply #5 on: February 14, 2007, 07:30:26 pm »
Thanks :applaud:
SodaPopinksi
  • Last login:November 09, 2011, 03:38:29 pm
  • Cold, Smokey, Rich Diet Caffeine Free Coke
    • John Keeler
« Reply #6 on: February 14, 2007, 10:52:28 pm »
Awesome, I didn't know about this or how to do it, now I do. It should satisfy the George Costanza in all of us  ;D
Now to finish my cab and finally get to playing, almost, almost!!
"Seimitsu LB-39's make me thirsty"- SodaPopinski
DarkDraco
  • Last login:June 30, 2016, 03:42:53 pm
« Reply #7 on: February 15, 2007, 03:06:13 am »
i followed that guide the other day and for some reason my compiled version of mame wont play any roms. it just says files are missing
FrizzleFried
    • Idaho Garagecade
« Reply #8 on: February 15, 2007, 10:15:44 am »
Did you compile the correct HISCORE.DIFF?   I assume you did as it would have likely errored out when you attempted to compile.
I don't know what to say?   I haven't had any problems thus far.   Are you having problems with ALL roms or just a select few?
What version were you updating from?
DarkDraco
« Reply #9 on: February 15, 2007, 11:47:31 am »
im using the 112u1 diff with 112u1 source. tried compiling twice and when i try to run galaga or pacman i get the error:
54xx.bin not found
FrizzleFried
    • Idaho Garagecade
« Reply #10 on: February 15, 2007, 11:49:38 am »
I dunno about Pac Man,  but I DO know that Galaga has a new ROM set as of v112u1.   You need a new ROM set for that.   Also,  try to run PUCK MAN instead of PAC MAN and see if it runs (PAC MAN is a clone actually).
DarkDraco
« Reply #11 on: February 15, 2007, 12:01:16 pm »
all the galagas new in 112u1? i tried all the versions and clones too, theres like 10 of them. can u tell me a game that works with 112 romset so i can test when i get home?
FrizzleFried
    • Idaho Garagecade
« Reply #12 on: February 15, 2007, 12:09:23 pm »
All clones use files from the parent set and the parent set has been changed.   Try running a few other games or go get the new rom sets (there are like 15-20 new rom sets for 112u1 I believe).
FrizzleFried
    • Idaho Garagecade
« Reply #13 on: February 15, 2007, 12:13:30 pm »
Also,  what was your last version you were running?   If you are updating from an old version,   MANY MANY MANY roms have changed between then and now,  if you are updating from 112 itself (not u1),  then only like 15 or so have changed.
This is from the latest WHATSNEW.TXT:
Replaced implementation of Namco 54xx sound chip with new MB8844 CPU
core running the original embedded ROM code. Removed old sound core.
Pole Position and Bosconian no longer require samples as a result.
So I am assuming that any game that errors out with 54xx error needs a new ROM set.
« Last Edit: February 15, 2007, 12:15:57 pm by FrizzleFried »
DarkDraco
« Reply #14 on: February 15, 2007, 12:16:05 pm »
i updated my romsets every mame update. so ive been up to date.i dont update romsets by updates, only the big releases .110, .111, .112 etc
Havok
« Reply #15 on: February 15, 2007, 02:45:08 pm »
There is a 112u1 ROM update - it came out yesterday. Somewhere...
DarkDraco
« Reply #16 on: February 15, 2007, 03:56:25 pm »
guess ill try updating my set to 112u1 to see what happens. but i did just run puckman and it worked but the highscore was blank and when i got a score on there and exited it didnt save. so meh T_T
DarkDraco
« Reply #17 on: February 15, 2007, 06:02:07 pm »
ok for anyone that cares and has same problem as me, you need to run mame -createconfig, then edit the ini file and set hiscore_directory to where u want hiscores saved. thanks for everyone that helped
PS: whats the latest hiscore.dat version? im using 105 cuz thats the only one i could find. if theres a new one can i get a link? i didnt see any newer
« Last Edit: February 15, 2007, 06:04:17 pm by DarkDraco »
Shoegazer
« Reply #18 on: February 15, 2007, 09:04:25 pm »
Well, I can appreciate the fact that some folks have taken the renegade approach by reanimating hiscore.dat, but since this solution will become increasingly difficult to manage over time, I still see the future as being linked purely to save state support.
So, I'm still curious to know if anyone is aware of any development efforts underway to fix this issue so we can keep the old save states with each new mame release?   On the surface it *seems* to be a minor bug, and since it obviously has major impact it would be great to know if someone was at least looking into it.  I looked in MAMEtesters and didn't see this as a reported issue, though I could be missing it.. am I right, or blind?
Shoegazer
« Last Edit: February 23, 2007, 08:08:48 am by Shoegazer »
Shoegazer
« Reply #19 on: February 23, 2007, 08:09:04 am »
Quick update: I keep looking around for some sign of hope but am coming up zeroes.  Anyone here have any real evidence that someone is looking at making save states compatible across releases?  This is the biggest "ouch" in MAME right now.. though I'm sure it is a well known problem since it must be very high visibility.
Buddabing
« Reply #20 on: February 23, 2007, 10:20:12 am »
I dimly recall reading a post from Aaron on mame.net regarding this topic. So try searching there. But I could be wrong and there was no such post.
Please read the wiki!
