Author Topic: Tekken 3 Wiring Diagram  (Read 4388 times)
Bleagh
  • Last login:October 18, 2016, 04:33:25 pm
    • BLEAGH!
« on: February 10, 2007, 06:57:43 pm »
Does anyone have a Tekken 3 manual or at least the wiring diagram they could share? or know where where to find it?
Kevin Mullins
    • Me on Myspace
Re: Tekken 3 Wiring Diagram
« Reply #1 on: February 11, 2007, 02:53:12 am »
http://arcarc.xmission.com/PDF%20Arcade%20Manuals%20and%20Schematics/Tekken_3_Operations_Manual.pdf
Anything specific you needed to know?
It's basically a jamma cab wiring setup aside from the extra buttons.
Bleagh
    • BLEAGH!
« Reply #2 on: February 11, 2007, 05:45:29 pm »
Thanks for the link!
I was looking for a pinout of the six pin dc power connector on the back corner of the board but It doesnt seem to be in the manual.
« Last Edit: February 11, 2007, 10:56:14 pm by Bleagh »
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
« Reply #3 on: February 15, 2007, 06:22:10 am »
When I got my cabinet it had been converted to Tekken 3. The board is fried, but the only connectors used were the two edge connectors (JAMMA and the kick harness).
I'm not sure what that connector is for, but it's nothing to do with hooking it up to the cabinet. You might check out the manuals for some other Namco System12 games. Here's a good list:
http://www.system16.com/hardware.php?id=535
Since System12 was designed to be a base hardware for many games (it's playstation-based), it may just be an auxillary connector that wasn't used for Tekken 3.
My Mr Driller 2 (system10) PCB also has this connector, but it isn't used on it either.
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: February 15, 2007, 09:24:05 pm »
THat connector is for the Japanese "JVS" cabinets. You don't need to worry about it, because the board also gets power through the JAMMA harness.
