Author Topic: Microsoft .Net Question  (Read 1189 times)
acevedor2
  • Last login:May 25, 2024, 08:21:24 pm
« on: February 09, 2007, 07:26:14 pm »
I just finished building the new PC and downloading all of the updates.  Normally I pay attention and selectively install the updates.  This time, however, I just selected all and installed.  The problem is that it installed the .Net framework.  With the .Net framework, it installes a .Net user and because of that whenever the computer is restarted, it brings you back to the welcome screen.
Should I just uninstall the .Net framework, or should I remove the .Net user?  If I remove the .Net user without uninstalling the .Net framework will I run into any problems?
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
TalkingOctopus
    • My Arcade
Re: Microsoft .Net Question
« Reply #1 on: February 10, 2007, 01:49:58 am »
I don't believe the .NET framework loads until it is needed.  I think you can let it be without worrying.  But then again, I don't know what you mean by .NET user.
acevedor2
« Reply #2 on: February 10, 2007, 08:01:52 am »
Once you install the .net Framework it creates a user account "ASP.Net"
The way XP works is that if you have 2 user accounts you will always get the "choose user" screen when you reboot he computer.  That is a problem for a cab because you don' want to have o click your user to get you into windows and mame.
I am trying to find the best way to fix this issue.  I think ultimately I will just end up uninstalling the .Net framework.  Any other options anyone can thin of.
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #3 on: February 10, 2007, 08:25:49 am »
Try to use AutoLogon feature for Windows XP
http://support.microsoft.com/kb/315231
I hope you will reach an english page from your computer.
If not just use google  and search :   autologon under win xp
acevedor2
« Reply #4 on: February 10, 2007, 01:20:39 pm »
Thanks Youki!  That did the trick.  Works great now.
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
