Author Topic: Need default config for IPAC4  (Read 2504 times)
edwardvci
  • Last login:February 23, 2009, 08:56:49 pm
  • Insert Coin.........!
« on: February 05, 2007, 11:18:07 pm »
Can some one help? I reprogrammed my ipac4 by mistake and now I want to load the Mame defaults back in. WinIpac's default is not the Mame default. If anyone has the file it would be appreciated. I have the one without the jumpers (new ver)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: Need default config for IPAC4
« Reply #1 on: February 06, 2007, 04:06:04 am »
You can also reset to defaults using the built-in configuration mode.
Start Notepad and using a keyboard connected to the pass through, press CTRL-ALT-P. This will type a menu on the screen. Then press R then E.
Andy
« Last Edit: February 07, 2007, 10:04:39 am by AndyWarne »
edwardvci
« Reply #2 on: February 06, 2007, 07:48:24 am »
edwardvci
« Reply #3 on: February 06, 2007, 06:23:52 pm »
Start Notepad and using a keyboard connected to the pass through, press CTRL-P. This will type a menu on the screen. Then press R then E.
Andy
If anyone else reads this it CTRL-ALT-P
Thanks for the help everythings back to normal :applaud:
