Author Topic: I changed my windows shell to mamewah and noe explorer wont work. Please help!!  (Read 1275 times)
mumbles
  • Last login:January 25, 2024, 09:20:01 pm
Hi,
in my mame cab I changed the shell from windows to Mamewah so that now you don't see windows explorer at all. I then set up in the mamewah ini to launch windows explorer when mamewah exits. When i exit mamewah it goes back to the windows desktop but I can't use windows explorer at all so can't change anything or access any of my foldes ect etc. The keyboard doesn't work either. How can I fix this!!
Thanks in advance
BLah247
  • Last login:June 12, 2014, 08:01:53 am
This happened to me as well.  So I logged in as Admin and deleted the profile I had done that to.  I then made a new profile and then just put MAMEWAH in the startup folder.
So when XP starts MAMEWah boots right up.  But I can exit and use all my other windows apps.
loadman
  • Last login:Yesterday at 07:18:10 pm
    • MaLa
while in mamewah
Hit:
cntl-alt-delete
Then select task list
from that window should be a pull down window
File-  New task
Type: explorer
All good  :-)
