Author Topic: For those with right/left mouse wired to player control buttons. Help...  (Read 1314 times)
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
I have a trackball dedicated cabinet (see my sig).  I use a JPAC for monitor and player controls.  I also use the Electric Ice Trackball (with support for 3 mouse buttons).
I did not want to add dedicated left and right mouse buttons to my control panel, so I wired:
- the left mouse button to share Player 1 Button 1 (mapped to letter A)
- the right mouse button to share Player 1 Button 2 (mapped to letter S)
This setup is not working that great.  Whenever I click on stuff in Windows, the letter A or S is also pressed.  Confuses the heck out of windows explorer. hehe...  I tried to change to CTRL and SHIFT, but that was worse.
For those that share mouse controls with player controls, what key mappings do you use?
Is there a way to have the JPAC only work in Mame/Front End(Mala), then have it load a different config in Windows?  If you can pass config via commandline to the JPAC, I should be able to load mame config on mala startup, then when I exit, load a windows-safe config.
Thanks for any ideas.
Edge
« Last Edit: February 03, 2007, 05:29:46 pm by edge »
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
Re: For those with right/left mouse wired to player control buttons. Help...
« Reply #1 on: February 03, 2007, 05:49:34 pm »
I don't have my mouse buttons on my action buttons, but can't mame be mapped to use the mouse buttons instead of keyboard keys? Simply disable the key presses from the buttons altogether.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
edge
« Reply #2 on: February 04, 2007, 12:00:11 pm »
Good point. I will try that out.  Thanks.
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« Reply #3 on: February 05, 2007, 10:46:14 pm »
Did this work out for you?
