Author Topic: Connection to PC and consoles?  (Read 1699 times)
JamesMolloy
  • Last login:November 12, 2003, 04:03:38 pm
« on: April 04, 2003, 10:55:39 am »
Is there some way to be able to plug PS2, Dreamcast and PC to your arcade controls in an easy switchable manner?
As much as I like MAME it would be nice to play Ikaruga, Soul Calibur and Virtua Fighter 4 when I feel like something more modern.
« Last Edit: April 04, 2003, 10:56:10 am by JamesMolloy »
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Connection to PC and consoles?
« Reply #1 on: April 04, 2003, 11:42:26 am »
here's a link for ya
quickly:  A. hack a console controller (see link) and get converters for different sytems
B. Get an x-arcade PCB and get the different adapters...
C. hack a billion different controllers and figure out some new magically way to switch between them without one consoles controller interfering with the other consoles controller (i.e. isolate them electrically from eachother)
Good luck!
rampy
« Last Edit: April 04, 2003, 11:43:57 am by rampy »
radiator
  • Last login:April 18, 2013, 07:14:43 pm
  • SFA OK!
    • :: verticalcircle ::
« Reply #2 on: April 04, 2003, 02:35:00 pm »
i have a question about this...
i plan on having a pc and dreamcast in my cab...for pc, buttons hooked up through my ipac, and for dreamcast the buttons will be directly wired to the pad (hack) - just want to know if this will be ok (no interference), as long as both machines aren't on at the same time?
*m
When the Germans bombed the British, the British ducked.
When the British bombed the Germans, the Germans ducked.
When the Americans started bombing, everyone ducked!
AX
  • Last login:April 20, 2004, 02:07:53 pm
  • The only way to win is to cheat!
« Reply #3 on: April 04, 2003, 02:36:26 pm »
I thought of this but decided against it.  somehwhere somehting is going to go wrong no matter how careful you are.  What I am doing is making my control panel easily removeable na dmaking a sep control panel for console games.
seaner
  • Last login:October 21, 2003, 02:10:16 pm
    • http://www.beerbot.ca/mame
« Reply #4 on: April 04, 2003, 02:41:01 pm »
You should be safe as long as only one is powered on at a time.
You're doubly safe if you aren't also driving 5V or something into either system.  ie. if your controls all work by grounding switches.
rampy
  • *shrug*
« Reply #5 on: April 04, 2003, 02:50:19 pm »
*m
It's my understanding (as this question has come up before) that it's not a good idea, particularly with the dreamcast...  unless you find a way to isolate each control element (i.e. diodes or switch(es), or to plugin/activate only one at a time or something)
*shrug* ymmv
rampy
JamesMolloy
« Reply #6 on: April 04, 2003, 05:23:18 pm »
Hrm.. complicated. I thought I'd be able to get connectors to plug into an iPAC. Maybe they'll come up with something like that in time. The X-arcade PCB can handle it so it's obviously possible. I'm just not wild about going down that route because they charge alot for simple connectors and crap controls.
OK, so I can build a control pannel from hacked PS pads and buy connectors to hook to PC or DC. Lucky I have a friend who knows something about wiring.
« Last Edit: April 04, 2003, 05:28:29 pm by JamesMolloy »
rampy
  • *shrug*
« Reply #7 on: April 04, 2003, 05:30:05 pm »
Well it's not *that* expensive... you can get the pcb separate y'know...  if you aren't savvy with a soldering iron you can pay a smal premium for a ready made solution...  (although the switching part would still need to be manual, regardless)
*Shrug*  good luck, though!
rampy
radiator
  • SFA OK!
« Reply #8 on: April 05, 2003, 03:25:13 pm »
has anyone out there actually done this (PC and DC in same cab) and got it to work well?
if anyone can give me any tips that'd be great
*m
