Author Topic: Help Removing Epoxy from Metal CP Surface *Screens*  (Read 1001 times)
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« on: January 31, 2007, 11:18:43 am »
Ok well my friend thought he would remove the protective coating from the sheet metal half way through the project. I have no idea, anyway I hate to have to redo this sheet so how can I get this epoxy off of the surface? I tried goo b gone spray and it did nothing at all.
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
Re: Help Removing Epoxy from Metal CP Surface *Screens*
« Reply #1 on: January 31, 2007, 03:09:01 pm »
what is your plan for the cp? do you have an overlay you are putting on it? if so i would not worry too much about it.
mrserv0n
« Reply #2 on: February 01, 2007, 03:22:25 pm »
I was able to get it off just took a while. No I am leaving it with the brushed steel. I see no reason to put a plexiglass surface over top as the stuff is pretty scratch resistant. 1/2 way through wiring it up now, Ill try to have a fresh pic up tonight
daywane
  • GRRRR!
« Reply #3 on: February 01, 2007, 10:38:12 pm »
spray with WD40
let sit for a bit.
like 1/2 hr
wipe glue off
clean with hot soapy water.
