Author Topic: Killer Instinct  (Read 1729 times)
Razor
  • Last login:October 03, 2008, 12:59:59 pm
  • Welcome to the fantasy zone
Killer Instinct
« on: January 29, 2007, 06:03:46 am »
I noticed people had some problems with this in the past, was wondering if there is a fix for it at all?  The game itself seems to run fine on my cab, but the audio stutters which spoils the experience.  Im running it on an athlon 2800+, 256mb ram, the version im running is 1.5d.
I did consider using Ultra64, but didnt want another emulator running in my cab, preferring to keep it simply Mame.
« Last Edit: January 29, 2007, 09:10:28 am by Razor »
needlesmcgirk
  • Last login:September 15, 2009, 10:54:31 pm
Re: Killer Instinct
« Reply #1 on: January 30, 2007, 01:35:53 pm »
Sounds like your cpu just isn't fast enough.  I'm 95% sure that is the problem.  You can always try getting another 256 MBs of RAM and see if that helps.
MustardTent
  • Last login:February 22, 2015, 12:14:02 pm
    • Blog
Re: Killer Instinct
« Reply #2 on: January 30, 2007, 02:18:34 pm »
What version of mame are you running?
chris2922
  • Last login:March 26, 2023, 01:09:41 pm
  • Silverline Jamma Cab
Re: Killer Instinct
« Reply #3 on: January 30, 2007, 03:49:05 pm »
Using Mame 0.89beta I set up a cab running on an Athlon 3000+ with 512MB RAM and it was plenty fast enough to run Killer Instinct 1.
(KI2 is a bit more processor hungry though and certain levels become unplayable.)
Make sure you're running the latest version of Mame.
MustardTent
    • Blog
Re: Killer Instinct
« Reply #4 on: January 30, 2007, 05:05:09 pm »
That's what I was getting at.  His problem may be that he's using a new version of mame.  Try using an older one, like what chris2922 mentioned -- mame089 or maybe something from the mame09x line.
Razor
Re: Killer Instinct
« Reply #5 on: January 30, 2007, 07:02:39 pm »
Okay guys thanks for the replys, im using the very latest command line mame, ill try it with an older version, if not ill wack another 256mb in the system see if it makes a difference.
