Author Topic: Competition Joystick help...  (Read 1422 times)
scoddie007
  • Last login:March 08, 2012, 09:29:58 pm
« on: January 28, 2007, 10:02:04 pm »
I ordered 2 Competition Joysticks but have not received them yet and just wanted to get a jump on the know how and hole drilling, Ive found alot of info of the buttons, 1 1/8" spade bit for the buttons, but never seen what size hole for the joysticks and another thing to mount them do i need to disassemble them. I so ancy to get my stuff to start piecing it together. One last thing how far from the joystick should the buttons be I'm looking for a street fighter style 6 button config. and buttons spacing iv got the consensus 1 1/2" center to center.
thanks,
Scott.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
Re: Competition Joystick help...
« Reply #1 on: January 28, 2007, 10:23:56 pm »
on a similar note...
do joysticks come with paper templates...?
if they don't...they should...
Arcade82
  • Last login:November 01, 2008, 06:40:56 pm
« Reply #2 on: January 29, 2007, 12:01:59 am »
You can use the same hole 1.125" (err 1 1/8" if my math is wrong) for a joystick.
No paper templates.
What you're gonna do is take off the E ring, take out the shaft, undermount the black part that has all the microswitches, reinsert the shaft through the hole from the top, put the actuator back on then fasten the E clip.. Very simple.
"Yeah... at least he built a cabinet. I can't wait to see yours. "
aahahahaa
markrvp
  • NFL Expert
« Reply #3 on: January 29, 2007, 09:28:01 am »
I personally don't like the buttons 1-1/2" center to center.  There's too much gap between buttons.  I like it so that the buttons are as close together as possible.  Just my personal preference.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #4 on: January 29, 2007, 12:58:56 pm »
Here's a drilling template. Just print without scaling and ignore the button center points if you're not using the classic 6 button layout.
It's 9am. I'm calling it a nite.
