Author Topic: Pin and wire  (Read 1134 times)
Franchise5
  • Last login:January 28, 2007, 06:34:19 pm
Pin and wire
« on: January 27, 2007, 02:24:19 pm »
I am making a start button for my cabinet.  I have a Sunset Riders Cabinet and bought Wrestlefest to put in it, but needs a start button.   I need to put a pin and wire in the spot for it on the pin board, or whatever it is called.
Where is the best place to pick up a pin and wire for such a job?
Will my local Radio Shack have what I need?
rackoon
  • Last login:February 16, 2026, 06:26:24 pm
  • I EAT PENCILS!
Re: Pin and wire
« Reply #1 on: January 27, 2007, 05:03:33 pm »
There is a part that is sold at radio shack called a shunt. Its sold in baggies of ten I believe. (Don't buy the jumper they look the same.)
The shunt will slip onto the two pins on your motherboard that your computercase power button would have been connected to. Then you can stab two wires into the end of the shunt and hook the other end up to a momentary switch. Done deal! :applaud:
Or you could just buy a power switch extention for $2.00 off the net. :P
They treated me like an animal and that's what I became.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Pin and wire
« Reply #2 on: January 27, 2007, 06:26:46 pm »
It must be me, but I have no idea what either of you are talking about ...
 :dizzy:
EDIT: Found the other thread and Kremmit had already done the translation:
http://forum.arcadecontrols.com/index.php?topic=62547.msg0#new
« Last Edit: January 27, 2007, 07:28:55 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Pin and wire
« Reply #3 on: January 27, 2007, 11:42:51 pm »
He doesn't want a computer start button.  He's after a pin to go in his JAMMA connector.
All further replies to go in the original thread...
« Last Edit: January 27, 2007, 11:45:47 pm by Kremmit »
rackoon
  • I EAT PENCILS!
Re: Pin and wire
« Reply #4 on: January 28, 2007, 04:33:38 pm »
I feel like a  :tool: now. Sorry, it sounded alot like my start buttom saga. Thought I was helping.
