Author Topic: trouble with skateball pinball  (Read 2897 times)
tk1959
  • Last login:February 01, 2007, 07:35:20 pm
« on: January 27, 2007, 07:59:02 am »
I have a bally skateball piball game. The problem is if you hit both flippers at the same time the game shuts down. I had a pinball service tech in town look at it and he was unable to determine why. I have changed all the flipper coils with new one. Anybody have any ideas what else to check?
Kevin Mullins
    • Me on Myspace
Re: trouble with skateball pinball
« Reply #1 on: January 27, 2007, 09:17:59 am »
Sounds like a current draw on the power supply of some sorts.......
Take a look here:
http://www.pinrepair.com/bally/index3.htm#reset
SirPeale
  • Green Mountain Man
« Reply #2 on: January 27, 2007, 12:39:12 pm »
Check your bridges first.
Check your power connectors for burnt ones.
This is pinball 101.  Sounds like you need a different tech.
tk1959
« Reply #3 on: January 27, 2007, 07:04:15 pm »
Thanks Peale and Kevin. Kevin that sight you gave me was great. I will check everything later
tk1959
« Reply #4 on: January 30, 2007, 09:32:30 pm »
Kevin,
ended up being the capcitor, I replaced it and everything is fine. Thanks :applaud:
« Reply #5 on: January 31, 2007, 09:13:32 am »
You still want to check your connectors for burnt ones.  Those hard crashes kill connectors and burnt connectors eventually kill other things that are much nastier than a dead filter cap.  Any connector that has burn marks on it or around the male headers needs to be replaced.  Not cleaned, replaced entirely, both male and female sides.
