Author Topic: Lightweight transportable Cabinet?  (Read 3118 times)
YoungAnimaniac
  • Last login:April 03, 2003, 11:05:54 pm
« on: April 03, 2003, 06:47:30 pm »
I've got a full size cabinet at home, and it's great but I think I'd like something smaller so that it doesn't take over the whole room. Has anyone seen plans for a small upright cab?
I'm thinking of something made mostly of aluminum, the same width and height as a standard cab, but without the marquee. Really slim it down by pairing it up with a nice 17" LCD and a SFF CPU.
Just imagine taking a portable arcade with you to a lan party...
Any thoughts?
Cue-Ball
  • Last login:August 28, 2006, 07:43:02 pm
  • Discs of Tron > *
    • Grant's Game Grid
Re:Lightweight transportable Cabinet?
« Reply #1 on: April 03, 2003, 07:02:58 pm »
If you're going to go the route of using an LCD i'd say don't even bother building an entire cabinet.  Just build yourself a full size control panel and make the screen something that either wall mounts or attaches directly to the CP.  Or, make it even EASIER and build a full size CP, put your computer bits inside, then use TV-out to connect to any S-Vid capable television.  That would give you ultimate portability and a very small, light package.  I may end up doing just this sometime in the future.  I'll still keep my full size cabinet, but this would be great for gaming on the big screen (i actually had my current CP setup this way for a few days while i was doing work on the cabinet itself).
anthony691
  • Last login:January 29, 2016, 03:10:23 pm
    • Lightgun.tk
« Reply #2 on: April 03, 2003, 10:39:24 pm »
Oh come on! That is hardly the same! I think an LCD in a full sized aluminum cab would be cool. I don't think just having a CP is even comparable to having a cab!
Visit my MAME lightgun site:
http://www.lightgun.tk
YoungAnimaniac
« Reply #3 on: April 03, 2003, 11:09:50 pm »
For me, part of the experience of playing an arcade game is standing up, but the portable CP would be a great idea for couch play. I know they have collapsable tables that are used for tradeshows and such. They're pretty stable, and very lightweight.
zorg
« Reply #4 on: April 04, 2003, 02:39:36 am »
If I was abble, ie: rich enough ;) to use a flat screen either LCD, or some plasma TV
I wish i'll build a kind of flatten 1UP style arcade. By flatten I mean: just depth enough to hold the CP
Eric
I'm on the planning stage
Cue-Ball
  • Discs of Tron > *
    • Grant's Game Grid
« Reply #5 on: April 04, 2003, 12:45:43 pm »
No, it's not comparable.  That's why we all build cabinets when it would be much easier to just do a CP or use the computer. But he already has a full size arcade machine and said he wants something portable.  "Portable" and "6 foot tall arcade cabinet" do not mix. :)
marcoval
  • Last login:December 02, 2004, 02:40:59 pm
  • www.scottishninjas.com
« Reply #6 on: April 04, 2003, 04:56:47 pm »
You know if I were wanting to make something portable and I was working on my 2nd cabinet, I would consider going cocktail..... Use lighter materials and I think you would be set.
Every millennium
A warrior emerges.
Trained in the deadly arts of the ninja.
Moving with the swiftness of the wind
Striking with deadly accuracy
They are proud
They are strong
They're Scottish
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #7 on: April 07, 2003, 01:39:54 pm »
I had been thinking in those directions, but the weight of stuff adds up quick. Now I'm thinking of something along the lines of an AV cart. Some sort of wooden framework attached to the PC Case, on casters, with the monitor bolted down. It'll still be heavy, but I'll be able to move it into the living room and out on the porch easy enough.
Bob
MrArcade
  • Last login:May 29, 2025, 02:06:06 pm
  • I wish I had time to play these games !!!
« Reply #8 on: April 07, 2003, 04:25:57 pm »
One thing to consider is weight....cabinets are heavy and do not move when two adults get into exciting gameplay.  If you make the cabinet easy to move...it will move during gameplay.  This would not be good in my opinion.
Oh, the memories of living on pizza subs and Dr Pepper...
Distortion
  • Last login:June 10, 2016, 04:39:20 pm
  • Saints Row 2, Sucka
    • Volition
« Reply #9 on: April 07, 2003, 04:59:24 pm »
think of a cabinet cut off below the control panel.  It's been done before, and if you put it on a table, it's at a good height to be standing up and playing.
Game programmers do not play games for a living.  Would you say a mechanic drives cars for a living?
Lilwolf
« Reply #10 on: April 07, 2003, 05:55:52 pm »
How about this for an idea.
A mini - TV, or super small LCD VGA (can you find a small 1/4 vga) hacked together with usb thumb pad.  The two are hacked together to look something like a gameboy.
Then, have them plug into a laptop.
So when you are on a plain, you have a handheld with battery support... Just a cable that goes between your notebook thats under your seat.
zorg
« Reply #11 on: April 08, 2003, 03:46:30 am »
talking about lightweight/small/transportable cab, I guess one could find some inspiration here
http://www.inanna.com/~calhoun/projects.html
Eric
