Author Topic: Problem with 3.1.3  (Read 4837 times)
garyh
  • Last login:January 26, 2011, 02:30:17 am
  • If God rides a Harley then the devil rides an LC.
Problem with 3.1.3
« on: January 20, 2007, 04:37:21 pm »
Hi Chris,
My MAME cab runs 3.0B4 as it does everything I want, however I'm about to build a new jukebox for parties and wanted to use a later version so I downloaded 3.1.3 .  I have a spare Win98SE laptop that I wanted to use for this project but I have a problem in that once a song has been selected it moves from the queue to the "now playing" display but only for an instance and then it disappears (and doesn't play)!  I tried 3.0B4 on the laptop and that is fine.
Any ideas?
Best regards
Gary
p.s. should I give up hope on a working Win98 touchscreen version?
garyh
Re: Problem with 3.1.3
« Reply #1 on: January 21, 2007, 06:25:59 am »
I'll move progressively through the releases today and see where it stops working. I really want the volume control so hopefully B5 will be okay, but I also like the idea of the "scratchy record" intro (being a bit retro).
Chris
  • Moderator
    • Chris's MAME Cabinet
« Reply #2 on: January 21, 2007, 03:44:43 pm »
Do you know what sound chip is in the laptop?
--Chris
garyh
« Reply #3 on: January 31, 2007, 05:04:03 pm »
Chris
I tried upgrading my MAME cab with 3.1.3 and got the same problem as with the laptop. What I have found is that if I select a track that is an OGG file it plays the scratchy record intro then the track disappears from the now playing display and there is no music. If I choose one of my few MP3 files it works perfectly.
I have also tried removing all pre/post delays and #ing the prerec.wav but it still does the same.
Do OGGs work for you?
Regards
Gary
garyh
« Reply #4 on: January 31, 2007, 05:27:15 pm »
Chris,
Just tried 3.0B11 and that works fine.
Gary
garyh
« Reply #5 on: January 31, 2007, 05:28:11 pm »
Chris, forgot to say that my MAME cab runs DOSCab.
Chris
  • Moderator
« Reply #6 on: January 31, 2007, 10:00:28 pm »
It's probably related to the change in Allegro versions; that happened between 3.0b11 and 3.1. I'm not sure if I've tested OGG's since then.  Hmm.  Good troubleshooting; I'll take a look at it.
--Chris
--Chris
Chris
  • Moderator
« Reply #7 on: April 23, 2007, 12:39:35 am »
I've found the problem; it'll be fixed in the next version.
--Chris
