Author Topic: LHUPATECH's Skin Catalogue Download Center  (Read 4221 times)
LHUPA
  • Last login:September 03, 2019, 01:05:09 am
« on: January 20, 2007, 02:45:18 am »
Recently, I have discovered an interesting alternative way to upload skins files larger than 512ko simply by downloading a forum's user skin by www.savefile.com. Finally, I have tried it and I was satisfied! And then, I have rebuilt all skins that I have submitted formerly with all functions. Now, all of my skins are complete with the possibility to download them, jukebox and control.ini files (for avoiding to rewrite your own jukebox' .ini files. Also, you have the possibility to download the complete package of 5 skins at a time and it is the same thing for .ini files. Simply cut and paste your own skin folder content, .ini files on a disk to save it in the case you want to re-install your own ones and unzip (.rar) and install the new ones you have downloaded from LHUPATECH! - The download skin center figures below with all download links to www.savefile.com. All files will be available for 30 days according to Save Files. But I will to check it every 30 days period. If you want to download a skin and the link dead, simply send me an e-mail at lhupatech@globetrotter.net and I will "repair" the defective service.
(April / 4 / 2007)
Please note that in the future all .INI files will be included in the skin file himself avoiding you to download these files separatly with the risk of downloading the bad file . (But, all .INI files for all my material is sensibly the same.) Suite to a problem notification of a user (Perhaps the user downloaded the bad .ini file causing disfunctions to his skin!), I have decided to bundle it to skin file. If you download . INI files for a skin below, make sure that you download the good associated .INI file for your skin project.
LHUPATECH'S SKIN CATALOGUE DOWNLOAD CENTER
All links to www.savefile.com - All files are in .rar
FIXED DIMENSION: All skins are in "height" mode.
LINKS FOR SKINS
Package all 5 skins :                                http://www.savefile.com/files/420876
INDIVIDUAL SKIN FILES
Lhupatech Schenectady* (English) :            http://www.savefile.com/files/419945
Lhupatech Schenectady* (French) :            http://www.savefile.com/files/419949
Lhupatech LHA -1 - B :                             http://www.savefile.com/files/419936
Lhupatech LHA -1 - A :                             http://www.savefile.com/files/419926
Lhupatech Scanlog LHA -1 - C :                  http://www.savefile.com/files/419918
Lhupatech SCANLOG III LHF 1 FESTIVAL :     http://www.savefile.com/files/577218
Lhupatech SCANLOG III S3X 3000-M SOUND LEISURE :        http://www.savefile.com/files/580241
Lhupatech SCANLOG III SYMPHOMATIC ALLEGRO 128 (With .ini files "control" and "jukebox" included) :                                               http://savefile.com/files/608545
EXTRA SKINS (Last added)
(Same color as LHA - 1 - C: Green back lighted index or selecting panel)
These skins use the same .ini files as all other skins.
It's only the index or select panel color that change!
Lhupatech LHA -1 - B Extra Skin (Grn Indx)  http://www.savefile.com/files/425013
Lhupatech LHA -1 - A Extra Skin (Grn Indx)  http://www.savefile.com/files/425027
LINKS FOR JUKEBOX AND CONTROL .INI FILES
(If you don't want to re-write your own Control and Jukebox .ini files.)
Package of all 5 control jbx .ini files :         http://www.savefile.com/files/420939
Lhupatech Schenectady* .ini files (Fr.) :      http://www.savefile.com/files/420947
Lhupatech Schenectady* .ini files (E) :        http://www.savefile.com/files/420951
Lhupatech Scanlog LHA - 1 - C .ini files :     http://www.savefile.com/files/420954
Lhupatech LHA - 1 - B .ini files :                 http://www.savefile.com/files/420957
Lhupatech LHA - 1 - A .ini files :                 http://www.savefile.com/files/420961
.ini files :                                                http://www.savefile.com/files/577393
INI files for SCANLOG III S3X 3000-M SOUND LEISURE :
                                                            http://www.savefile.com/files/580255
*The Schnectady skin is especially designed for cabinet mount projects.
I hope that these skins give you a lot of satisfaction!
Good Lock!
Lhupa
« Last Edit: April 04, 2007, 05:39:49 pm by LHUPA »
LHUPA
Go to "LHUPATECH's Skin Catalogue Download Center"
« Reply #1 on: January 20, 2007, 02:54:38 am »
Apologies! it was an error! I have erronously clicked the "quote button"!
« Last Edit: March 25, 2007, 04:54:42 am by LHUPA »
LHUPA
« Reply #2 on: January 20, 2007, 03:00:06 am »
Apologies dear friends I have tried to bring corrections to this topic and I have made errors!
« Last Edit: March 25, 2007, 04:57:45 am by LHUPA »
