Author Topic: Do these 4-way sticks mount in 3/4"?  (Read 2613 times)
Magnet_Eye
  • Last login:May 11, 2020, 09:26:19 pm
  • Feel the heat?
    • Web Hosting deals for BYOAC Users!
« on: April 03, 2003, 02:01:22 am »
This guy (8liners) is always selling these "Galaga/Ms-Pacman" sticks...I wonder if they would mount in 3/4" wood CP's?
Anyone know? I think these are the Happs ones.
oops! forgot the link: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3216992332&category=3945
Thanks.
« Last Edit: April 03, 2003, 05:26:47 am by Magnet_Eye »
I offer discounted WEB HOSTING to BYOAC members! Only $2.49 a month for a FULL FEATURED account! www.cloud9media.com
kspiff
  • Last login:February 02, 2016, 09:15:36 pm
  • Love of the game, baby.. love of the game..
Re:Do these 4-way sticks mount in 3/4"?
« Reply #1 on: April 03, 2003, 05:33:16 am »
They will fit, but I think they are made for a metal CP.. many have just routed out under the CP so the stick isn't too short and travels right.  That or -- less economically -- buy Oscar's mounting plates (or make your own).
k-spiff
mcleanjoel
  • Last login:May 26, 2005, 06:56:52 am
« Reply #2 on: April 03, 2003, 06:10:29 am »
Does this model have a diamond-shape restrictor built in for the 4-way feel?
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #3 on: April 03, 2003, 01:56:24 pm »
I'm wondering the same thing...
-Ace-
I want my own arcade controls!
Nervous
  • Last login:May 25, 2005, 08:48:50 pm
  • * sigh *
« Reply #4 on: April 03, 2003, 06:05:57 pm »
Those Happ 4-ways are definitely made for a metal CP.
The Happ part description says: "Shaft length for metal mounting only"
I put them into a 3/8" CP and the shafts were really short.  I'd go with routing underneath to make them stick up higher.
Cue-Ball
  • Last login:August 28, 2006, 07:43:02 pm
  • Discs of Tron > *
    • Grant's Game Grid
« Reply #5 on: April 03, 2003, 07:10:31 pm »
Has anyone ever tried mounting these from ABOVE the CP?  You know, just route out a square the same size and depth as the sticks base, then mount it from above?  Seems like this would be super easy to do and would give great results.  I'm considering doing this myself but was hoping someone else already played guinea pig.  ;D
kspiff
« Reply #6 on: April 05, 2003, 12:58:57 am »
Someone probably has tried this before, but I wouldn't.. if you plan to put art over your control panel, you'll have to make a choice between not covering the joystick base and never removing your joystick :P
k-spiff
Cue-Ball
  • Discs of Tron > *
    • Grant's Game Grid
« Reply #7 on: April 05, 2003, 01:19:07 am »
I don't see any reason for that to be the case.  If you can remove the lexan covering the CP, you can remove the overlay graphics since they would be exactly the same (same hole positions and cutouts).
kspiff
« Reply #8 on: April 05, 2003, 03:50:55 am »
That would depend on whether or not you adhesive the art or just lay it on, I guess.. hadn't occurred to me since I plan to adhesive mine.
Also, though, you'd have to be OK with removing pretty much everything to get the 4-way stick out (should the need arise)..
But I don't get it.. and seriously, here.. how is it in any way easier to route above the CP than below it..?  Or is joystick height the main concern there..?
k-spiff
Magnet_Eye
  • Feel the heat?
« Reply #9 on: April 05, 2003, 06:05:32 am »
wtf kspiff! wHY DO YOU HAVE SUCH A BIG AVATAR IMAGE?
kspiff
« Reply #10 on: April 05, 2003, 07:07:34 am »
Yeah, this avatar is kinda big.. but at least it isn't wide so I have to scroll horizontally to read some msgs..
It was one of the default selectable ones here @ arcadecontrols, though.. and as to why, well.. Protoman rules.. they should make a Megaman game with just Zero and Protoman 8)
k-spiff
Cue-Ball
  • Discs of Tron > *
    • Grant's Game Grid
« Reply #11 on: April 05, 2003, 09:12:25 pm »
It's not an issue of ease, it's purely an issue of joystick height.  Mounting the stick from the top gives you 1/2" more stick height which many people prefer.  And, of course, if the stick is designed to go under a thin metal CP, then you'd definitely need to mount on the top if using wood just to keep the "stock" stick height.
GearHead
  • Last login:January 01, 2022, 11:24:59 am
  • need more gear...
« Reply #12 on: April 05, 2003, 10:25:57 pm »
It's not cheap but you could buy the Pac Man mounting plate for the joystick or make your own.  Top mount the plate using a router and then mount the joystick from underneath. You get the right height and accessibility.
