Author Topic: WTB: Happ Universal Video Converter "UVC"  (Read 2282 times)
zelony
  • Last login:November 16, 2019, 04:00:12 pm
    • Green Chavez Law Firm
« on: January 17, 2007, 11:39:26 am »
I am looking to buy a Happ Universal Video Converter.  This is the device that will take almost any VGA input and output to either standard arcade or to medium resolution arcade, which is what I need it for.
I do NOT want an ArcadeVGA card, but thanks for the suggestion.
Thanks,
Jeff
« Last Edit: January 17, 2007, 08:05:26 pm by zelony »
pointdablame
Re: WTB: Happ Universal Video Converter "UVC"
« Reply #1 on: January 17, 2007, 01:27:55 pm »
Wouldn't an ArcadeVGA do the same thing at less than half the price??
first off your and idiot
zelony
« Reply #2 on: January 17, 2007, 02:29:07 pm »
No.  I have a MEDIUM resolution monitor.  The ArcadeVGA does NOT support that.
But thanks for trying to look out for me.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: January 17, 2007, 06:20:30 pm »
Not quite true anymore ... support is limited (details in the thread), but ...
Incidentally the new card also supports 25Khz for multi-sync monitors.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
zelony
« Reply #4 on: January 17, 2007, 08:04:36 pm »
That's all fine and dandy, but I don't want to hook this monitor up to a computer, hence the reason for the UVC.
CheffoJeffo
« Reply #5 on: January 17, 2007, 08:09:46 pm »
I was responding to the specific statement you made ... never said it would help you.
EDIT: Added in old post to avoid further pollution but also to avoid misleading those who run across this in a search ...
It looks to me like it supports the Medium Resolution output on multisync monitors only.  There is no mention of true fixed frequency medium resolution monitors.
So if you connect a 25k-only monitor, there would be no boot screen and you would be able to use ony two of the resolutions in Windows. This is not really a limitation of the card, but of a 25K monitor.
Sorry to pollute your thread, but you keep saying things that aren't quite right and someone is going to find this in a search and be mislead. It would have been much easier if you had just said "I can't use an ArcadeVGA" in the first place since the reason you can't use it is unrelated to the misinformation you posted about it.
MODS: Feel free to remove my responses to the incorrect info, but please remove the incorrect info as well. Then the thread will be nice and neat.
Cheers.
« Last Edit: January 18, 2007, 10:25:10 am by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
zelony
« Reply #6 on: January 18, 2007, 10:11:06 am »
However, I don't really care.  This thread was put here to see if anyone had a UVC for sale.  Not to debate the ArcadeVGA's coolness factor.
