Author Topic: AUTO RUNNING on XP  (Read 5426 times)
Karaokedude
  • Last login:October 16, 2007, 12:21:00 pm
AUTO RUNNING on XP
« on: January 15, 2007, 06:46:38 pm »
not sure if any one would know this but here goes
I can get Wincab to startup automatically no problem
and on exit to shut down windows totally ( after installing SP2)
what i am trying to do is run some kind of batch file so i could have
say 2 seperate  versions of the software with different parameters mainly the song selection
as i want to have different directorys with different types of MP3s in but wnat to be able to somehow chose which  directory to use
blicky
  • Last login:August 08, 2011, 06:57:02 pm
Re: AUTO RUNNING on XP
« Reply #1 on: January 16, 2007, 06:01:38 am »
not sure if this is what you mean but running this batch lets you select which ini file to use.  All you have to do is save your jukebox.ini as a different filename but in the index section specify a different songpath. (You can also have different skins, credits anything)
Edit the batch file where i have "newskin" to whatever name you use.
copy and paste into a new file e.g. wincab.bat
@echo off
: :: the directory where wincab lives
cd\juke
: :: change the on screen message to whatever you like e.g. playlist1, playlist2
echo For cd skin press 1
echo For newskin press 2
set/p ini=[pick skin]
if %ini%==1 goto cd
if %ini%==2 goto new
:cd
wincab jukebox.ini
goto end
:new
wincab newskin.ini
goto end
:end
Karaokedude
« Reply #2 on: January 16, 2007, 08:48:17 am »
ill give it a try should be fine
i was going to try a batch file but realised they have done away with the choice command in XP
Karaokedude
« Reply #3 on: January 16, 2007, 08:53:30 am »
Works a treat
Chris
  • Moderator
    • Chris's MAME Cabinet
« Reply #4 on: January 16, 2007, 09:23:17 am »
Thanks for catching this one for me, blicky!
--Chris
Karaokedude
« Reply #5 on: January 16, 2007, 07:40:43 pm »
is there a switch to run in full screen i was going to add to the start up would be nice if it was full screen
I miss pure dos  :(
i was going to run on a dos pc but just thought how does 6.22 handle the ID3 tags and long file names ??
Karaokedude
« Reply #6 on: January 16, 2007, 07:43:29 pm »
Answred my own question on the full screen option
created a shortcut to the batch file and set the options of the shortcut
Chris
  • Moderator
« Reply #7 on: January 18, 2007, 01:11:05 am »
I miss pure dos  :(
DOSCab reads the tags just fine; if all your songs are tagged properly the file names won't be an issue.  They'll all be cropped, but you'll never see them.
--Chris
