Author Topic: Particle board or MDF  (Read 4608 times)
remakes
  • Last login:April 22, 2003, 11:54:38 pm
« on: April 02, 2003, 12:41:10 pm »
I am going to be heading to Home Depot later on today to purchase all the wood for my cabinet.  Now comes the ever popular question, what type of wood to get.
I have done a little research and have found that there are probably advantages to both.  I will be going with 3/4" regardless of the type.  The main issues are:
1) Cost
2) Abilitly to hold screws
3) Best for T-molding
Is the advantages with going with MDF over particle outweigh the extra cost (a little less than twice as much per board).  I have worked with particle board quite a bit in the past, and have good sucess with it, but those of you who have built cabinets have appeared to lean towards MDF.
« Last Edit: April 04, 2003, 01:29:36 am by SirPoonga »
remakes
Re:Particle board of MDF
« Reply #1 on: April 02, 2003, 12:44:22 pm »
Sorry, that should read "Particle or board OR MDF"
Jakobud
  • Last login:June 30, 2025, 02:20:39 pm
« Reply #2 on: April 02, 2003, 01:46:34 pm »
MDF
seaner
  • Last login:October 21, 2003, 02:10:16 pm
    • http://www.beerbot.ca/mame
« Reply #3 on: April 02, 2003, 01:52:16 pm »
I used 5/8" particleboard on mine.. no problems at all, even got the t-molding in with no issues.  You'll probably find that the MDF is more expensive.
There was a thread on this within the last week already, perhaps you should read that one?
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #4 on: April 02, 2003, 01:53:12 pm »
You could use Particle Board, but I can't think of a single property about particle board that would make it  better.
There are pros and cons of choosing regular plywood over MDF, but no particle board.  Bring your weight lifing belt if you are getting 3/4" MDF...
This opinion was created from 100% post consumed information.
Nervous
  • Last login:May 25, 2005, 08:48:50 pm
  • * sigh *
« Reply #5 on: April 02, 2003, 01:54:45 pm »
How about plywood?  That's pretty much all I ever use.
It holds screws really well, and doesn't weigh as much as MDF.
T-molding hasn't been a problem either.
_Iz-
  • Last login:August 04, 2025, 11:11:12 pm
  • Time to coin up!
« Reply #6 on: April 02, 2003, 03:00:30 pm »
Plywood doesn't paint up as nicely as MDF.
Jakobud
« Reply #7 on: April 02, 2003, 03:04:08 pm »
I used 5/8" MDF.  If you don't mind shelling out a little more for MDF rather than particle board, you will be very very satisfied.
Nervous
  • * sigh *
« Reply #8 on: April 02, 2003, 03:13:28 pm »
You're absolutely right.  MDF does look pretty good when painted.
SirPoonga
  • Puck'em Up
  • Last login:July 20, 2025, 03:37:24 pm
  • The Bears Still Suck!
« Reply #9 on: April 02, 2003, 03:33:56 pm »
plus patching mistakes with mdf is so easy when combined with wood putty....
RandyT
  • Last login:Today at 02:07:32 pm
    • GroovyGameGear.com
« Reply #10 on: April 02, 2003, 03:41:58 pm »
Stay away from particle board at all costs.  It's far less durable than MDF.  Melamine isn't all that hot either, as it is very similar to particle board inside.  But it does have a nice pre-made finish.
I wouldn't use plywood unless you plan on laminating it, or you spend the extra for hardwood laminated or MDO.  Otherwise it'll just be ugly.
MDF was engineered for low cost cabinetry with all the desireable properties that go with that application.  In other words, it was designed for what you want to do with it :).  How well your project comes out with MDF (or any material for that matter) will depend on whether your construction methods are compatible with the material.
There are lots of different pieces of hardware that are specially designed for this type of material.  If you choose to take shortcuts or use hardware designed for other purposes, the quality of your project will probably suffer as a result.  Most of the time, the individuals that give MDF a bad rap never really gave it a proper chance.  A little research goes a long way.
RandyT
unclet
« Reply #11 on: April 02, 2003, 04:31:50 pm »
Dont use particle board....you are going to have this cabinet (you are making from scratch) around a long time, so you should make sure it lasts over the years....
I used 3/4 MDF board for the sides of my cabinet and for the control box and used 1/2 MDF board for all other panels.
IG-88
« Reply #12 on: April 02, 2003, 04:39:31 pm »
I never have understood why everyone wants to go with 3/4 - 5/8 material anyways. I mean 1/2 with the inside corners screwed to 2x2's makes for a very stable cabinet at ALOT less weight and costs. Braced stategically, I wouldn't be afraid to use 3/8! Am I missing out on something?
-HarumaN
RandyT
« Reply #13 on: April 02, 2003, 05:38:58 pm »
I think a good portion of the commercial cabs were made out of 3/4" material.  This made them heavy and durable.  The weight makes them more stable and less likely tip over when someone get's PO'd at the game and gives it a good kick :).  The wood was also the only thing between the public and what was in the coin boxes, so that may have had a role as well.  Less framing (no framing?) is required with 3/4", which means lower labor costs and quicker assembly.
The average person probably isn't worried about any of that stuff, so it might be overkill.  But my personal feelings are,  if it can't stand up to the abuse of the real deal it's not very authentic.  I like a good solid "thump" when the side of it is slapped, rather than a hollow wooden drum sound :) .
RandyT
SirPoonga
  • Puck'em Up
« Reply #14 on: April 02, 2003, 06:11:52 pm »
plus I only had 3/4" mdf has a choice.
Nervous
  • * sigh *
« Reply #15 on: April 02, 2003, 08:08:16 pm »
I kinda like the appearance - the thicker material looks "beefier".
remakes
« Reply #16 on: April 02, 2003, 11:06:52 pm »
Well, I decided to go with 3/4" MDF (that thing is going to weigh a TON, but it will last me a long time).  I already have most of it drawn out on the board, and should start cutting tomorrow.  So far, so good.
spidermonkey
  • Bombjack junkie
« Reply #17 on: April 03, 2003, 12:11:19 am »
I used "Ultralight" MDF. It does cost more then standard MDF but well worth it. Its 30% lighter then standard MDF. Considering that it takes at least two 4 x 8 sheets to build a cabinet 30% is ALOT of unwanted weight shaved off your project. My cab is pretty big and is still very and I can't imagine how heavy it would have been if I hadn't used ultralight  :P I have casters on my cab but they don't help when I'm humping the thing up and down stairs. I've moved twice in the past year. All of which were 2nd floor condo's so I could kiss myself for spending the extra money for the light stuff.
"Sinistar has bad breath"
SirPoonga
  • Puck'em Up
« Reply #18 on: April 03, 2003, 12:12:41 am »
make sure you put a good coat of primer on
remakes
« Reply #19 on: April 03, 2003, 11:37:28 pm »
Got it all cut out today and started sanding a bit.  I will finish that tomorrow, and start looking for paint.  I believe I will go with a black (yea, I know it's boring, but it will match everything else in my room) with T-molding.  Does anyone know where to get the bit that's used for T-molding?
RandyT
« Reply #20 on: April 04, 2003, 12:04:04 am »
I hate to be one of those guys that says "do a search on the forum", but you should do one :).
There was a pretty informative thread not too long ago that listed a number of good and inexpensive sources for what you seek.
RandyT
SirPoonga
  • Puck'em Up
« Reply #21 on: April 04, 2003, 01:30:00 am »
Hehe, modified it for you, just hit the modify button of the first post, you can change the title.
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #22 on: April 04, 2003, 02:08:41 am »
http://mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html#Anchor
you want #301
remakes
Re:Particle board or MDF
« Reply #23 on: April 06, 2003, 01:46:35 am »
Got the majority of the pieces sanded and am in the process of making sure everything is going to fit right, and should start the assembly probably Monday.  I went and bought some semi-gloss black paint as well as some primer.  Coming along nicely!   :)
