Author Topic: Screen tilting  (Read 1024 times)
clockwork
  • Last login:December 11, 2008, 11:15:29 pm
  • Time to play!
Screen tilting
« on: January 14, 2007, 05:45:48 pm »
Two questions. I've been planning my cab using the Project Arcade book. The book shows the monitor shelf being horizontal. If I want my screen tilted back, should I tilt the shelf or use a different method? I'm worried about preventing the monitor from sliding back.
Also, the book measures the shelf at 34" from the cab base. The front of the cab is 33". That's only 1" above the cab front, yet Saint says, and according to the picture, the shelf is just above the control panel. So really the shelf is at about 38-39". Is there a guideline to how high above the control panel the monitor should be for a comfortable view?
Charlie Brown: I'm still hoping that yesterday will get better.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Screen tilting
« Reply #1 on: January 14, 2007, 07:45:19 pm »
Shove a bit of wood in behind the base of the monitor. Or screw it to the shelf.
No... The answer is in your question! make it high enough for a comfortable view, and so that it looks right, in the space.
Don't stick slavishly to other peoples plans!.... The only time you need to do that is if you're making a 100% accurate replica cab.
Make it work for what you want yourself.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
  • Last login:Today at 05:09:27 pm
Re: Screen tilting
« Reply #2 on: January 14, 2007, 08:22:15 pm »
Best Regards,
clockwork
  • Time to play!
Re: Screen tilting
« Reply #3 on: January 14, 2007, 09:27:37 pm »
Thanks. Actually I realized that the height is already set for me given the design I'm using. So I just need to worry about the angle. I'll probably take your suggestion and just shove a piece of wood back there.
