Author Topic: Need help with Mame32 - won't start games!  (Read 6108 times)
Dashman
  • Last login:January 21, 2007, 09:59:15 pm
« on: January 12, 2007, 08:18:41 pm »
OK .... I'm new and thoroughly frustrated! I have both MAMEand MAME32 installed - all my ROMS work fine in MAME. I got Mame32 put the romsin the ROM folder (unzipped),and fired it up! Says it found em,and they are "working". But if I double click a game, the screen just flashes,and then back to mame32 - no windows open up at all. Checked the directories setup .. looks fine .. any thoughts?
KLM
Naru
  • Last login:June 29, 2007, 12:01:34 am
Re: Need help with Mame32 - won't start games!
« Reply #1 on: January 12, 2007, 08:29:50 pm »
The ROMs need to be zipped.
The ROM folder remains unzipped.
That's all I know.
There's a lot smarter people here
than me, so you've
got a good chance of finding out
the problem.
Dashman
« Reply #2 on: January 12, 2007, 09:14:16 pm »
All that is fine  :(
IG-88
« Reply #3 on: January 12, 2007, 09:15:23 pm »
Naru is right. Make sure the roms are zipped inside the ROMS folder. Then run a game audit.
-HarumaN
Dashman
« Reply #4 on: January 12, 2007, 09:20:52 pm »
Ran the audit,went to "working",clicked on a game that is supposed to work, said it was fine, clicked run and it just flickered and back to mame32 again
loadman
    • MaLa
« Reply #5 on: January 12, 2007, 09:42:47 pm »
.. any thoughts?
Try setting up another version of mame32 in another directory.
Havok
  • Trade Count: (+17)
« Reply #6 on: January 13, 2007, 01:41:38 am »
Your ROMs version has to match your Mame version. Check out this program:
ClrMamePro
If they don't, then get an older\newer version of Mame32:
JoyMonkey's Mame32 Archive
Since you have Mame and Mame32, verify you are pointing Mame32 to the correct ROM directory, under Options, Directories,
-or-
Try deleting the Mame32.ini file and re-run Mame32
-or-
Experiment with your video modes under Options, Default Game Options, Display. Try swapping DirectDraw/Direct3D.
« Last Edit: January 13, 2007, 01:50:17 am by Havok »
ahofle
    • Arcade Ambience Project
« Reply #7 on: January 13, 2007, 04:34:18 pm »
I just had this happen yesterday.  It's not the roms because he would have gotten an error msg.  I rebooted and the problem went away.  :dunno
SirPeale
  • Green Mountain Man
« Reply #8 on: January 13, 2007, 09:19:25 pm »
It's none of these things.
Link 1
Link 2
langdoguk
  • Last login:October 30, 2009, 03:45:23 pm
  • hey you Guys !
« Reply #9 on: January 14, 2007, 07:44:55 am »
I had the very same problem . Tried loads of things but still couldn't get it to work . Downloaded Atomic FE  :applaud: and hey presto I was playing games within about 2 minutes , the plug and play modules are the dogs  :censored: for people like myself who are not the best at all this .
But I am the best at WONDERBOY   :cheers:
Help I'm useless !!!!
