Author Topic: DreamCast Analog Control on Arcade Stick  (Read 2404 times)
silvercrw
« on: March 30, 2002, 08:21:31 am »
HEy guys I just hooked up my dreamcast sucessfully to my perfect 360. Thanks for all the help. I wonder if any knows a way to wire the analog controls to the joystick as well. I know its only 8 way but X-arcade wired it so that if you hold on the joystick in a direction for like a second longer it emulates the analog stick. Does any know a way. There are alot of games that you need to use the analog, Thanks for the help
Jon
Garvv
Re: DreamCast Analog Control on Arcade Stick
« Reply #1 on: March 30, 2002, 01:31:32 pm »
try the dc2jamma writeup at:
http://www.mameworld.net/pc2jamma/arc_dc4.html
It details wiring up the hall effect sensors of the analog controls to digital inputs.
CthulhuLuke
  • Last login:May 22, 2025, 01:03:42 am
  • old school
    • CthulhuLuke's Arcade Parodius
« Reply #2 on: March 30, 2002, 09:13:21 pm »
Hey SilverCrw, how do those perfect 360s feel?  do you play any fighting games like Capcom vs SNK 2 on it? or do you just play other types of games on it?
 If so, how does the perfect 360 respond to fireball movements?  is it smooth and what not, or is it a little hard since there are no corners or anything?
 -sorry I don't know much about the analog joystick on the dreamcast pad
 -CthulhuLuke
