Author Topic: Monitor keeps going blank  (Read 3259 times)
F_Zero45
  • Last login:July 15, 2013, 10:10:32 pm
« on: January 07, 2007, 06:00:35 pm »
Having the same problem with 2 games. A Turret Tower and SF Rush. What's happening is that the monitor board keeps going out and , of course, the screen goes blank. The boards have been sent off for repair and when they are put back in the game the screen comes on for a few seconds and then goes blank. Sent boards back for repair and when we recieve them back same thing. The company that repaired the boards doesn't give a discription , in the invoice or anything, of what actually went out on the board and what went out or was replaced. What should be looked at for this kind of situation?
oh, the actual monitor & chasis have been replaced in the SF Rush, thinking it might have been something going on with it, but same thing happends.
kjoel0123
  • Last login:January 07, 2012, 09:57:19 am
  • Cabs for sale - Please see my flickr page for all
Re: Monitor keeps going blank
« Reply #1 on: January 07, 2007, 09:20:42 pm »
Do yourself a favor and call Chad at arcadecup.com , he just repaired my monitor and did a  kick ass job !!
Dedicated Cabaret cabs I currently own:
Neo Geo/ GT Complete/Mspac galaga reunion
full size cabs: Playchoice 10 Single Monitor/Nicktoons Racing/Junior King Cocktail/ Super Punchout/
Pins- Revenge From Mars/ Black Rose/ LW3
For Sale/ Trade: Digdug in Ireland Cab/83' Chexx Hockey/Battlezone/PC10 Bartop with 6 games
Check out http://www.flickr.com/kjarcade <--not updated
F_Zero45
« Reply #2 on: January 07, 2007, 10:23:25 pm »
like i said. the monitor boards have been repaired a few times but when the board is instlled and the game is powere on it goes out again after afew seconds. I dont think it's the monitor board but something shorting it out. I just dont know what.
kjoel0123
« Reply #3 on: January 07, 2007, 10:46:42 pm »
Have you tested internal voltages with a volt meter? Power supply voltage? Do these units use a transformer for the monitors? Have you checked all solder connections, to verify that your joints are not loose? Checked loose connectors on the pcb? Checked  Molex conectors? Checked chip legs for broken legs/rust?  Tried another game board?
Kevin Mullins
    • Me on Myspace
« Reply #4 on: January 08, 2007, 12:36:12 am »
I'm not sure I understand if the GAME boards were sent off for repair or the MONITOR boards were. Your first post made me think the GAME boards were, but your second post made it sound like the MONITOR boards were. Can you clarify this?
Does the game play "blind" when the monitor goes blank?
(can you hear it running and coin up it up and play it but just can't see it)
What monitor models are you using / having trouble with?
Initially I would think this is a monitor problem, although you say that the monitor was totally replaced in the SF Rush and it still does it. (?)
grantspain
« Reply #5 on: January 08, 2007, 11:14:36 am »
it will be a right bummer if it turns out to be a faulty power supply
look at the facts two different game boards and two different monitors giving the same fault-highly unlikely
look towards a common component like power supply,cables or monitor remote board(this is when your multimeter pays for itself)
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
« Reply #6 on: January 08, 2007, 12:36:32 pm »
I am thinking dud psu in the cabinet
(assuming the psu is like mine where it powers the game board AND handles isolating the monitor supply)
F_Zero45
« Reply #7 on: January 09, 2007, 06:40:17 pm »
sorry guys, the monitor boards are being ent for repair. The Turret Tower is fixed but the SF Rush still goes out. Amother problem. It's pretty generic.
The screen goes blank. There is sound still. then you unplug the entire game and then plug it back in the screen turns back on. It'll stay on for a day or two then goes out again. Monitor boards power supply?
« Last Edit: January 09, 2007, 07:56:19 pm by F_Zero45 »
SirPeale
  • Green Mountain Man
« Reply #8 on: January 09, 2007, 06:44:08 pm »
What kind of monitor?  Sounds like a shutdown problem.
kjoel0123
« Reply #9 on: January 09, 2007, 08:52:47 pm »
I just had the same issue and it was a bad monitir board, however you could have a defective isolation transformer or a lack of..
grantspain
« Reply #10 on: January 10, 2007, 02:48:52 pm »
blimey,what monitors are you using that are so unreliable as to keep sending for repair
