Author Topic: CP Hinge Front or Back?  (Read 3494 times)
acevedor2
  • Last login:May 25, 2024, 08:21:24 pm
« on: January 06, 2007, 03:56:57 pm »
Ok, this may sund like a dumb question, but is there a reason everyone hinges their CP at the front? It would seem more intuitive that you would hinge it that the back so you could lift it up in the front when needd.
The only reason I can see that it would be hinged in the back is because it might interfere with the cab when you try to open it. Again, this is my first cab so I would like your thoughts.  Thanks as always for the expert advice!
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: CP Hinge Front or Back?
« Reply #1 on: January 06, 2007, 04:49:19 pm »
Convenience and ergonomics -- it is much easier to work on something that flips out clear of the cabinet to horizontal towards you than flips up to the vertical in front of the cabinet further away from you.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
miles2912
« Reply #2 on: January 06, 2007, 04:51:05 pm »
When you open the top you want it to go past top dead center to stay open.  That would cause controls to hit the monitor and or sides of the cab... and it might not stay open on its own.
Usually you don't need to get in there too much to do wiring and such.
Don
acevedor2
« Reply #3 on: January 06, 2007, 05:24:08 pm »
Great reasons, thanks.  I just wanted to make sure before I installed the piano hinge.  Cheers,
Ray
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
tranq
  • - Banned -
  • Last login:January 11, 2007, 05:04:35 pm
  • - Banned -
« Reply #4 on: January 06, 2007, 09:49:04 pm »
Oh.  I hadn't noticed this.  Good idea.  I was considering this feature, but then thought 'well, what will it be good for, really?'.  Mmm?
acevedor2
« Reply #5 on: January 06, 2007, 09:52:19 pm »
Yeah, I have seen it in most of the cabs, I just couldn't figure out why they always opened forward instead of the traditional way....now I know.  Cheers
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
JONTHEBOMB
  • Last login:March 28, 2025, 11:39:04 pm
  • BOOM!!!!
« Reply #6 on: January 06, 2007, 10:50:40 pm »
You are 100% correct.  I hinged the back of my control panel.  The control panel is right up against the cabinet so I can't open it all the way.  Everytime I want to mess with something inside the control panel, I have to go inside the cabinet, release the control panel clamps and remove it from the cabinet.  Well you live and learn.  For my second cabinet I will not make such a dumb mistake.
« Last Edit: January 06, 2007, 10:52:52 pm by JONTHEBOMB »
tranq
  • - Banned -
  • - Banned -
« Reply #7 on: January 07, 2007, 12:11:51 am »
Mmm, it's natural to want to open that way.  Sorta like cars: you can't get under 'em as well, vs those foreign ones in the 70s that opened by the windshield, but you can get to the front of the engine.  The uncommon difference with panels is that the guts come up with the top.
acevedor2
« Reply #8 on: January 07, 2007, 09:13:04 am »
Glad I posted this!  Now I will make sure to open from the back!
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
FrizzleFried
    • Idaho Garagecade
« Reply #9 on: January 07, 2007, 11:25:52 am »
Believe it or not...I almost hinged mine on the side...so it swung open like a door....
acevedor2
« Reply #10 on: January 07, 2007, 11:32:55 am »
That wouldn't be a bad idea.  It might actually work kind of nice.  Hmmm.....
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
tranq
  • - Banned -
  • - Banned -
« Reply #11 on: January 07, 2007, 02:59:17 pm »
Initially sounds like a neat idea....but the stability might be an issue - have to use tight hinges - and then there's the issue of the end being probly at least at eye level, which could be a countre to the feature.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #12 on: January 07, 2007, 03:09:17 pm »
Unless the CP top locks, I'd think you also want the hinge on the front to keep some asshat from opening it up "just to see what's inside"  ::)
Hopefully the brainpower in such an individual doesn't extend to figuring out just WHERE the hinge is ;D
acevedor2
« Reply #13 on: January 07, 2007, 05:48:31 pm »
Yep, I think I will continue with the tried and tru method of opening from the front.  Thanks again guys!
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #14 on: January 07, 2007, 08:17:23 pm »
Errrmmmm.......  My CP Hinge is at the back..... I can well see the points that you guys are making. But to be very honest, I've never had a problem with it being there.
The CP slides forwards out of an overhang... It almost sits into a slot. So it can't be opened unless I slide it forwards.  I've never had a problem with this as I have two quick release catches underneath it inside the main cabinet box.
It's also easier for me this way, as it allows all the cables to exit easily at the back of the CP Box.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
tranq
  • - Banned -
  • - Banned -
« Reply #15 on: January 08, 2007, 02:19:55 pm »
Your designs, perhaps?
CheffoJeffo
« Reply #16 on: January 08, 2007, 02:29:58 pm »
On my first cabinet (a three-sided cocktail), I hinged the panels on the long side ... I'll never do it again.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
ahofle
    • Arcade Ambience Project
« Reply #17 on: January 08, 2007, 05:17:54 pm »
This may be common knowledge, but I thought I'd throw in a recommendation for one (or two) of those spring loaded lid support devices which keeps your CP from slamming down.  This way you don't have to have the CP completely vertical to stay in place.  I saw this on a toy chest I recently bought for the kid (to prevent it from slamming on heads/fingers) and couldn't believe I didn't have one in my hinged CP.
http://www.kidsource.com/cpsc2/toy.box.chest.html
« Last Edit: January 08, 2007, 05:19:44 pm by ahofle »
FrizzleFried
    • Idaho Garagecade
« Reply #18 on: January 08, 2007, 05:41:09 pm »
...a pretty damn nifty idea there Ahofle...
tranq
  • - Banned -
  • - Banned -
« Reply #19 on: January 08, 2007, 06:12:40 pm »
You could also put in a little hood support rod.
DrewKaree
  • HAH! Nice one!
« Reply #20 on: January 08, 2007, 06:49:22 pm »
Keep your thoughts about rods to yourself
Mr. Bubblehead
  • Last login:May 16, 2007, 08:49:19 am
  • I use soap.
« Reply #21 on: January 08, 2007, 07:08:52 pm »
Honestly, how often do you need to access the underside of the control panel?  I have built at least a dozen cabs for both my self and others, and I have never hinged any of them.
If I don't like the layout of the controls, I just build another cab! ;D
acevedor2
« Reply #22 on: January 08, 2007, 07:41:46 pm »
Ahofle - that is a great idea.  Ironically I bought those about a week ago to go in my cab CP ;D
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
tranq
  • - Banned -
  • - Banned -
« Reply #23 on: January 08, 2007, 08:14:21 pm »
I'll have to remember your penchance for exitability.
CheffoJeffo
« Reply #24 on: January 08, 2007, 08:17:35 pm »
That Drew, he's always a handy way to leave ... wait ... EXITability ? PenchanCE ?
 :dizzy:
« Last Edit: January 08, 2007, 08:19:51 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
tranq
  • - Banned -
  • - Banned -
« Reply #25 on: January 08, 2007, 08:48:00 pm »
Whoops, I thought maybe penchant was verb form, and penchance noun.  In any case, that was a bit of dry humour, aye?
DrewKaree
  • HAH! Nice one!
« Reply #26 on: January 08, 2007, 10:02:37 pm »
It still doesn't explain exitability, nor your "super teh skeelz yo" wif de spleling ::)
Is this more of your "I can't be troubled to actually make sure things work/are correct before opening my gaping maw"?
I hear teh chickies, dey dig dat in a man.  You can test that out when you're out of puberty Lloydzmom.
tranq
  • - Banned -
  • - Banned -
« Reply #27 on: January 09, 2007, 01:33:50 am »
Drewwwwwwwwwwww.........you're certainly living up to your self-description, there.  Boot thas thi point, eh?
tranq
  • - Banned -
  • - Banned -
« Reply #28 on: January 09, 2007, 01:38:53 am »
...and....oh my....you're a christianiac.  I'm gonna have to indulge just this once:  :dizzy: :notworthy:
