Author Topic: MaLa question - launch external app on game start/exit?  (Read 9122 times)
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« on: January 06, 2007, 03:01:45 pm »
Hi,
Does anyone know if it's possible to launch an external app from MaLa when a mame game starts and then again when it exits (without coding a custom plugin)? I see that MaLa does have an option to launch a cp viewer when a games starts and I guess that could be used for any app - for example to set the DSR mode for a GPWiz49. But what about on game exit?
Robots will kill you.
Arcade Addiction
loadman
  • Moderator
    • MaLa
Re: MaLa question - launch external app on game start/exit?
« Reply #1 on: January 06, 2007, 04:02:46 pm »
Hi,
Yes (you have the right idea but use the encoder launcher) and yes (I think that where the default encoder conig Mala is used).
Options/controller/encoder  ;)
Let me know what you need and I'm sure a plug-in can be whiped up in any case. Fatfingers has already written a plugin for the Ultrastick in C++ so I'm sure he could give us some tips  ;D
Enjoy
« Last Edit: January 06, 2007, 04:13:21 pm by loadman »
arzoo
    • LEDBlinky
« Reply #2 on: January 06, 2007, 04:58:16 pm »
loadman,
I just downloaded Delphi 7 personal - I think I'll give the plugin coding a try myself. Might as well learn if I'm going to use MaLa!
Arcade Addiction
fatfingers
  • Got UltraStiks?™
« Reply #3 on: January 06, 2007, 05:07:13 pm »
It sounds like you guys have everything under control, but if I can be of any assistance, please let me know.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
« Reply #4 on: January 06, 2007, 06:05:19 pm »
loadman,
Arzoo,
You should also try Turbo Delphi.  I like the interface much better.  And it is also free.
http://www.turboexplorer.com/delphi
arzoo
    • LEDBlinky
« Reply #5 on: January 06, 2007, 07:40:19 pm »
loadman,
Arzoo,
Actually, I've got Delphi 7 and 2005. Do you think turbo is better than 2005? Will any of them work with the MaLa plugin interface?
Arcade Addiction
edge
« Reply #6 on: January 06, 2007, 11:17:35 pm »
They should all work.  I haven't tried 2005, but I think thats newer than the turbo version.
loadman
  • Moderator
    • MaLa
« Reply #7 on: January 07, 2007, 04:35:57 am »
loadman,
Cool.  I use D7 personal and it works for me. I don't think the Plug-in is too fusy what version you use as it only needs to recognise the external calls.
Eg
On game Start  ..
On Mala Start
On Screen Saver Start
Etc
I'm sure you could make one in VB (but there is no template for that yet)
As long as you are having fun
[EDIT] Now I have been using D7 for a while I may try TurboD and see what I think.. I will let you know
« Last Edit: January 07, 2007, 05:00:21 am by loadman »
arzoo
    • LEDBlinky
« Reply #8 on: January 07, 2007, 08:39:45 am »
I've been doing some reading on Delphi and I think Turbo is newer than 2005.
http://delphi.about.com/cs/azindex/a/dhistory_3.htm
« Last Edit: January 07, 2007, 08:42:31 am by arzoo »
Arcade Addiction
loadman
  • Moderator
    • MaLa
« Reply #9 on: January 26, 2007, 05:18:49 pm »
I decided to stay with D7
Had troubles downloading turbo :dunno
loadman
  • Moderator
    • MaLa
« Reply #10 on: February 03, 2007, 03:47:04 am »
Later...
Am now using Turbo Delphi 2006!
How did I live without this?  :dunno This is Gold!   :notworthy:
1) It appears Delphi 7 had a bug that caused me to look for a apparent prob with the Led-Wiz code that I now discover was never there AHHH! It works fine now  ;)
2) It spoon feeds you tips and highlights potential coding problems to you on the fly
I LIKE IT SIR...  Yes I DO   ;D
millercentral
  • Last login:March 07, 2024, 04:38:47 pm
« Reply #11 on: February 03, 2007, 08:45:53 pm »
Any Luck? Mala happily sets my 49ways to 2-way horizontal for Moon Patrol before it launches (thanks to calling Set49Way with the %rom% parameter), but when I quit and return to Mala the stick is still in 2-way horizontal mode, making it hard to scroll the game list in Mala... :)
loadman
  • Moderator
    • MaLa
« Reply #12 on: February 03, 2007, 09:58:43 pm »
Sorry are you suing a plug-in?
or if now how are you sending the command?
There is an encoder section in MaLa that was made for encoder keyboard encoders on game launch to diffrent configs but can just as easily be used to launch and set joystick configs as it's just command line based
If you send the command using the controller/encoder tab you can set a default config that can be loaded for MaLa use (default config)
millercentral
« Reply #13 on: February 04, 2007, 02:39:56 pm »
Yep, thats what I'm using and it works great for launching a game, but it doesn't "reset" the joystick back to 8-way after the game exits...
loadman
  • Moderator
    • MaLa
« Reply #14 on: February 04, 2007, 04:44:14 pm »
Can you post a screenshot of that encoder mala tab?
millercentral
« Reply #15 on: February 08, 2007, 11:43:11 pm »
Here you go (attached)...
loadman
  • Moderator
    • MaLa
« Reply #16 on: February 09, 2007, 12:09:45 am »
As I suspected you have not set a default config (mala) that MaLa loads after you quit a game..
Try that  ;)
