Author Topic: Encoding video  (Read 3422 times)
Valence
  • Last login:June 15, 2004, 10:44:49 pm
Encoding video
« on: April 01, 2003, 12:28:28 pm »
I'm trying to make a screen saver (kindof). What I'm doing is running Galaga full screen on my comp and then doing a video screen capture. What I want is a video of the intro and demo mode of Galaga. Like a 5 or 6 min video.  I'm using Windows media encoder that you can get for free from their site.
My problem is the lag. I'm using a 1Ghz with 512 Mb of ram  and a 64MB video card. If I don't encode it as full screen it works just fine. When in full screen mode, It jitters and the sound gets messed up. I've changed all the setting trying to decrease the resolution so that it doesn't jitter and I almost have it. But it will never be there.
Basically I was wondering if someone that has a newer, "beefier" computer can give it a shot. I have the knowledge but I don't have the hardware. I can walk someone through how to set it up if anyone wants to give it a try.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Encoding video
« Reply #1 on: April 01, 2003, 12:32:45 pm »
hmm.. sounds like you are doing 2 cpu intensive things at a time (although you'd think galaga would be less so =P)
I believe that AdvanceMame has video recording built in... so you could use AdvanceMame to do  your video capture and then do your actual encoding aftewards (instead of doing both at the same time)
note: I haven't actually done that ->and I *may* be confused.... but it might actually work for you=P
rampy
_Iz-
  • Last login:Today at 01:10:58 am
  • Time to coin up!
Re:Encoding video
« Reply #2 on: April 01, 2003, 12:59:00 pm »
Older versions of mame had the record AVI capability. If you get stuck find out the last version that could do this and use that. (PS, you can get all versions of mame from mame.net)
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
Re:Encoding video
« Reply #3 on: April 01, 2003, 02:11:59 pm »
Your problem is not your computer..  It's what your encoding the video with.
What format is the screen grab to begin with?  Also, what format do you want it to end up as (mpeg, mpeg2, mov(qt), avi(divx))?
Now with cup beer holders!
Valence
Re:Encoding video
« Reply #4 on: April 01, 2003, 11:36:22 pm »
Windows media encoder does them in WMA. As far is the end process is concerened. I could use any format.
_Iz-
  • Time to coin up!
Re:Encoding video
« Reply #5 on: April 02, 2003, 10:32:48 am »
Then grab an older version of mame that still supported recording to AVI (I believe uncompressed avi) and use TMPG or VirDub to re-encode to your preferred format (mpeg or divx).
Valence
Re:Encoding video
« Reply #6 on: April 07, 2003, 07:53:23 pm »
I can't find out which version supported recording. Any help?
_Iz-
  • Time to coin up!
Re:Encoding video
« Reply #7 on: April 08, 2003, 10:51:18 am »
This version apparently will...
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
Re:Encoding video
« Reply #8 on: April 10, 2003, 02:58:05 am »
Wow, what a cool feature!  I wish the newer version still supported this.  I grabbed the old build of MAME32 and was able to make some .avi's.  Unfortunately the roms for most of the games I want videos of don't work in the old version.  Is there a custom build of MAME that supports .avi capture?
-Ace-
I want my own arcade controls!
_Iz-
  • Time to coin up!
Re:Encoding video
« Reply #9 on: April 10, 2003, 11:26:20 am »
When you say they don't work do you mean they aren't supported in that version or are they supported but have been updated/redumped since and you don't have the old roms?
rampy
  • *shrug*
Re:Encoding video
« Reply #10 on: April 10, 2003, 11:50:00 am »
the latest advance mame supports video recording and latest/recent games...
http://advancemame.sourceforge.net/readme.html
*** Sound and Video recording in .WAV and .MNG files.
(mng is like PNG for movie files... and should be easily converted to whatever the heck you want, i think)  otherwise they would call it .MNG the merciless
*shrug*
Rampy
AceTKK
Re:Encoding video
« Reply #11 on: April 10, 2003, 12:27:09 pm »
A little from column A, a little from column B :-)  Marvel vs. Capcom was not yet emulated and Street Fighter 2 rom has been changed.  Mortal kombat series work fine though.
Thanks for the tip Rampy, I've been meaning to check out AdvanceMAME anyway.
-Ace-
