Author Topic: Leaf Joystick Issues?  (Read 5132 times)
codeena
  • Last login:December 03, 2023, 06:23:54 pm
  • This site is cool
« on: December 29, 2006, 03:45:05 am »
Hi all,
I bought a couple of new leaf based joysticks and have issues w/my Act Labs Powerramp joystick hack which works perfectly fine w/my Happ microswitch joystick. Sometimes I get beeps from my pc's speakers and sometimes the joy won't register movements or get stuck. Is there a difference between leaf connectors and microswitches that may be causing these problems? BTW (and slightly off the sub), the leaf joys had a diamond shaped opening but were supposed to be 4/8-way swapable. I had to round the diamond shape to make it easier to hit the diagonals.
Thanks in advance.
Level42
Re: Leaf Joystick Issues?
« Reply #1 on: December 29, 2006, 05:00:15 am »
If your joysticks are those cheap Chinese Wico fakes, take a look at this thread:
http://forum.arcadecontrols.com/index.php?topic=41573.0
then you'll know the only place for this rubbish is the bin.
Don't know what the Act Labs stuff is, but no there is no ELECTRICAL difference between microswitches and leafs. They either do or do not make contact. That's it. On the non-electrical part, leafs and microswitches are WORLDS apart. But that's a whole different story....
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #2 on: December 29, 2006, 09:02:58 am »
Carefully check how you have the new leaf switches wired...... Make sure that your ground connections are all made to the ground terminals on the leaf switches, and that none of them are connected to the NO or NC contacts. Buzz through your wiring with a meter.
Also check that all of the leaves of the switches are properly adjusted and not making contact at the wrong times. It sounds like a stuck leaf or incorrect wiring to me.
Leaf switches are tempramental and DO need periodic adjustment and setting. This is why the arcade industry moved over to microswitches, because when one of those fails you just chuck it away and stick a new one in.
The most likely cause of this problem is a short or an incorrect connection somewhere. Electrically there is no difference between a leaf and a microswitch.
Best Regards,
Julian (Fozzy The Bear)
« Last Edit: December 29, 2006, 09:05:51 am by Fozzy The Bear »
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
shardian
« Reply #3 on: December 29, 2006, 11:08:42 am »
The original leaf switches I have don't have NO, NC, or ground connections. It's just two strips of metal that complete a circuit when they touch. Am I missing something, or does this have to do with some new hybrid leafswitch that goes on a micro joy? I've seen a replacement leaf switch mentioned on here before, but have never looked into it.
Fozzy The Bear
« Reply #4 on: December 29, 2006, 11:45:50 am »
Joystick Leaf Switches come in lots of varieties..... Some have two leaves and some have three... So you can have NO and NC connections as well as the ground connection.
Some leaf switches used in Bally Midway pinball machines had up to six leaves with various connection arrangements.
Best Regards,
Level42
« Reply #5 on: December 29, 2006, 04:07:04 pm »
Whoah, yeah..welll if you are the first person using the NC connection of a microswitch in an arcade game situation, congratulations !
Indeed, indeed.....a REGULAR leaf switch is a NO (Normaly Open) contact.
MOST microswitches have both a NO (Normaly Open) and a NC (Normaly Closed) contact (and a common of course...) the electicity can flow either from the common to the NC contact (when untouched) or from the common to the NO contact (when pushed down)....
You can safely forget about the NC connection on the microswitches, you'll never use it in an arcade game situation. (Apart from special home-brewn applications !) Even better: forget about microswitches at all, they suck anyway :D
So let me refrase:
There is no ELECTRICAL difference between the COMMON and NO contacts of a microswitch and that of a REGULAR leaf.
« Last Edit: December 29, 2006, 04:09:04 pm by Level42 »
codeena
  • This site is cool
« Reply #6 on: December 29, 2006, 04:44:36 pm »
Thanks for the replies!
Yes, the joy I bought is the Chinese version and I'm not a fan of its performance/feel. I have an original Wico 8-way for my second joy and I will just look to find another one to replace the "leaf-style" one, which just doesn't feel right.
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« Reply #7 on: December 29, 2006, 04:54:58 pm »
Fozzy The Bear
« Reply #8 on: December 29, 2006, 05:13:35 pm »
i was just on ebay and saw these.  figured it might spark some interest.
http://cgi.ebay.com/ATARI-GAUNTLET-CONTROL-PANEL-JOYSTICKS-BUTTONS-PLUS_W0QQitemZ250067525059QQihZ015QQcategoryZ13718QQrdZ1QQcmdZViewItem
Hmmmmm... Wonder what happened to the rest of it.
Best Regards,
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: December 29, 2006, 05:25:53 pm »
Got me thinking:
Normal arcade leaf switches (from Bob Roberts)
some leaf switches with NO & NC (or 2-way depending on leaf bending)
Bazillion contact leaf switches ;D
Robin
Knowledge is Power
tranq
  • - Banned -
  • Last login:January 11, 2007, 05:04:35 pm
  • - Banned -
« Reply #10 on: December 30, 2006, 04:07:47 pm »
There's, I think, a new design reviewed at Retroblast:
http://www.retroblast.com/reviews/leaf-switch_bracket-04272006-01.html
Level42
« Reply #11 on: December 31, 2006, 11:19:00 am »
Got me thinking:
Sigh....... A NORMAL LEAF SWITCH AS USED IN THE MAJORITY OF VIDEO ARCADE GAME MACHINES
Satisfied ?
Level42
« Reply #12 on: December 31, 2006, 11:20:48 am »
That's leaf buttons, not leaf joysticks....
tranq
  • - Banned -
  • - Banned -
« Reply #13 on: December 31, 2006, 03:19:54 pm »
Hmmm, notice u_reb's is, also.   I incorrectly assumed they could be fitted for both applications.
Level42
« Reply #14 on: December 31, 2006, 08:07:17 pm »
Well, it could actualy, but in most joysticks it will be impossible to fit them in.
