Author Topic: Problems launching SEGA Genesis & Atari from MAMEWAH  (Read 2512 times)
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
« on: December 28, 2006, 11:59:35 pm »
2 similar questions, answers to either one are greatly appreciated.
When I attempt to launch Sega Genesis the MAMEWAH screen doesn't change, but I can here the game theme playing (like the games playing in the background, but I can't see it).
Here's my ini:
### Execution Settings ###
emulator_executable                       G:\EMUs\SEGA\gens.exe
commandline_format                        "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
When I attempt to launch Atari, the screen goes completely blank / black and I just hear a high pitched beep.
Here's my Atari ini:
emulator_executable                       G:\EMUs\Atari2600\Z26.exe
I'm running MAMEWAH 1.61.
I currently have MAME, SNES, Virtual Pinball, and Future Pinbal running just fine from MAMEWAH, but I'm trying to add a couple additional emulators.
Thanks!  MPTech
MPTech
   Better living thru technology!   ;-)
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
Re: Problems launching SEGA Genesis & Atari from MAMEWAH
« Reply #1 on: December 29, 2006, 09:21:30 am »
MPTech hi.
I have Z26 (atari 2600) running successfully under Mamewah 1.61 and Mamewah 1.62b12.  At this moment I'm at work.  As soon as I'm home and have the oportunity, I'll post her both configs.
If you're interested, I have the Z26 version that has the same mame buttons config.
Cheers, :cheers:
Congui.
MPTech
« Reply #2 on: December 29, 2006, 12:01:36 pm »
Thanks Congui, yes, I'd really appreciate it.  I don't know what version I have, I'll have to check.  I would prefer the same MAME buttons config.  please provide that as well (or a link so I can download it).  :cheers:
Any info on the SEGA?
What else do you have running under MAMEWAH?  I'll be adding more emulators later, just starting with these for the moment.
MPTech
jcrouse
    • CPViewer
« Reply #3 on: December 29, 2006, 12:40:50 pm »
I use MameWAH 1.62b12 but you can adapt the settings for your version. I also, as most people do, use Kega Fusion for all the Sega platforms, as opposed to GENS. Here are links to all of my INI files:
http://www.cpviewer.emuchrist.org/mamewahinifiles.htm
Enjoy,
John
MPTech
« Reply #4 on: December 29, 2006, 08:11:49 pm »
jcrouse THANKS!
that worked for SEGA. at first it was coming up in a window, then I added the "-gen -fullscreen" parameters and it looks great.
2 things to figure out next (I ran out of time tonite, we have about 30 people comin over for a party).
there are white numbers appearing in the lower left corner. for example 59.8 and it increments up and down a few tenths. never saw that before.
Also, I need to take the time to figure out how to map the buttons to my X-Arcade.  I'm looking for a Sega emu config menu. I'll check the KEGA site tomorrow, if you don't know off the top of your head.
THANKS again!  :cheers:
MPTech
gonzo90017
« Reply #5 on: January 01, 2007, 01:26:49 am »
Go to options and uncheck "show fps"
MPTech
« Reply #6 on: January 01, 2007, 01:50:43 am »
I'm launching from MAMEWAH and haven't figured out how to get to options yet.
MPTech
jcrouse
    • CPViewer
« Reply #7 on: January 01, 2007, 12:15:26 pm »
Getting to options has NOTHING to do with MameWAH. It is a function of the emulator itself. Good advice is to always get the emulator setup and configured without using the front end. Then finish by setting it up properly in the front end. The front end simply LAUNCHES the emulator. All of the emulator configuration needs to be done within the emulator first.
John
