Author Topic: minipac Jumpers (URGENT HELP NEEDED)  (Read 1395 times)
icesurf3r
  • Last login:September 13, 2013, 11:33:38 am
« on: December 23, 2006, 08:01:12 am »
Is the minipac supposed to have jumpers?? As mine has a mini-header on the board but no jumpers (my minipac has the self test green led).
It works fine when i program it in the test mode of the winIpac programming utility.  But the minute i turn the computer off it loses the setting, and i have to hit the "program" button again on the "key Assignments" screen.  Urgent help needed as this is a christmas present, just have the cp to get working and I'm starting to panic..
If it does need jumpers can someonelet me know the jumper configuration i need for programming the flash memory please
headkaze
  • 0x2b|~0x2b?
Re: minipac Jumpers (URGENT HELP NEEDED)
« Reply #1 on: December 23, 2006, 08:27:38 am »
Check out the ultimarc website, it shows you how to program it. You can either program it temporarily (settings are lost on power-down), or write to the EEPROM. You have to read the instructions on how to program it perminately. You shouldn't need to mess with jumpers.
icesurf3r
« Reply #2 on: December 23, 2006, 10:15:44 am »
Is it supposed to have jumpers though?  as mine doesn't have any.
Have tried programming to the eeprom using ctrl+alt+p in notepad, but even that didn't work.
Have tried the IPACFIX from ultimarcs website and still no joy getting it to save the settings
« Last Edit: December 23, 2006, 10:31:53 am by icesurf3r »
headkaze
  • 0x2b|~0x2b?
« Reply #3 on: December 23, 2006, 10:41:51 am »
Are you connecting your IPAC to your PC using a PS/2 connection or PS/2->USB connection.
You have to have a pure PS/2 connection I believe. BTW I'm no expert on this, I'm just trying to help out cos you sound desperate.
Apart from that I'm not sure what it could be.
icesurf3r
« Reply #4 on: December 23, 2006, 10:49:59 am »
nope it's PS2 -> USB
Problem solved!!!!!!! And all i did was switch it to another USB port on the same computer. How weird is that???
I can now go get everything else finished on the cab that i need to do, that i didn't do while i was panicking over this... My neice very nearly didn't have a christmas present..
But thanks for your help... The minipac is now remembering its programming  :D
« Last Edit: December 23, 2006, 10:58:40 am by icesurf3r »
headkaze
  • 0x2b|~0x2b?
« Reply #5 on: December 23, 2006, 01:30:07 pm »
Not all USB ports have power to them. I had the same issue with some devices that need power and plugging them into a powered USB port seems to solve that. Plugging into a pure PS/2 port would have solved it too ;)
Glad you got it sorted :)
EDIT: That reminds me, someone else made a post with the same issue as this!
« Last Edit: December 23, 2006, 01:51:27 pm by headkaze »
