Author Topic: WTB part for SCI cab or trade board for other horz arcade board  (Read 1406 times)
edwardvci
  • Last login:February 23, 2009, 08:56:49 pm
  • Insert Coin.........!
« on: December 22, 2006, 08:29:53 pm »
I got a Special Criminal Investigation cab for my church youth group awhile back and it has been working fine then the steering quite working. the part I need is the middle gear and post there is a gear mounted on the wheel than the one in the middle than the one for the optic board I need the middle gear or the whole steering assemble. the gear is striped and the post is bent and there is brass shaving. If you don't have a part any suggestion to fix it would be more than welcomed
Or trade board for another game that will work on horz monitor with 1 joystick and 1 or 2 buttons and is appropriate for a church youth group.
« Last Edit: December 25, 2006, 03:16:20 pm by edwardvci »
edwardvci
Re: WTB part for SCI cab or trade board for other horz arcade board
« Reply #1 on: December 26, 2006, 09:08:38 am »
2600
« Reply #2 on: December 26, 2006, 09:04:15 pm »
Is this a similar steering wheel?
http://www.happcontrols.com/driving/50283700e.htm
Give the part # for the part you need to ponyboy or divemaster127.
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
« Reply #3 on: September 08, 2007, 02:42:56 pm »
Did you ever fix this?
