Author Topic: Minipac keeps timing out - can't program it!!  (Read 1592 times)
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« on: December 20, 2006, 07:03:09 pm »
I seriously, urgently need some quick help!!!!
I've just had two PS/2 Minipacs from Ultimarc. I set one up on one machine, then programmed it using the iPac utitlity program, so that the buttons are mapped to keys I prefer (like tab, Enter etc.).
This worked fine on my other machines, but for some reason, this one refuses to program!
I've upped the timeout period to ten seconds, as I found sometimes the other machines timed out and only worked at around 6 or 7 seconds, but this one just refuses to work. Anything I can do?
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
Re: Minipac keeps timing out - can't program it!!
« Reply #1 on: December 20, 2006, 08:30:02 pm »
It's a shot in the dark, but try this:
1) Go into Device Manager in windows, and Uninstall ALL of your USB ports (Do not worry, they will all re-install on their own on next boot)
2) After doing the above step, then download this and double click on it.
When my I-pac4 would give out, I would do that procedure.
Goodluck.
Turnarcades
    • Turnarcades
« Reply #2 on: December 21, 2006, 02:58:12 am »
Will that work though? My ipac is the PS/2 (keyboard socket) version, not the USB version.
Flip_Willie
  • Last login:November 02, 2020, 11:20:46 pm
    • FlipWillie's Site
« Reply #3 on: December 21, 2006, 08:39:57 am »
 No, I highly doubt Postalp123's suggestion will help if it is a ps/2 connection.
 However, I would advise you to check and make sure that you have the ps/2 cord in the right sockect on the mini pac and in the correct socket on the motherboard.  ( Don't use the Mouse PS/2 slot on the motherboard. ) Then re-boot the pc.
  Yes, I know, very simple suggestions that you have probably already checked.  But if you plugged either end of the ps/2 cable in incorrectly, it won't work. Then again, it wouldn't work period.
Just as it is,
Flip Willie
postalp123
« Reply #4 on: December 21, 2006, 08:44:41 am »
(Smacks Forehead) Sorry, didn't see the PS2 reference, it was late when I read that last night.
Turnarcades
    • Turnarcades
« Reply #5 on: December 26, 2006, 10:36:26 am »
Thanks for the advice, but it turned out too be some sort of software issue. I plugged it into an identical PC I'd already used in another arcade and it programmed straight away.
I've e-mailed Ultimarc about the issue as the timeout delay seems to cause some problems it seems, so maybe it's something they can work on.
miles2912
« Reply #6 on: December 26, 2006, 03:38:10 pm »
My usb mini-pac looses programming every time the pc is re-booted or the cab is turned off.  I have 2 usb slots on the pc and I have tried them both.  What I do know is just have the programmer in start up and I hit program everytime the pc boots.  If someone has a permanent fix I hope they post it.
D-
