Author Topic: Question on Mala When Launching a Game  (Read 3856 times)
hsr
  • Last login:November 13, 2025, 09:33:28 pm
    • My Robotron Mame Cabinet
« on: December 15, 2006, 02:25:07 pm »
Download and test computer is a Celeron 2.53GHz with 256MB Ram running XP.  By "test", I mean the one I use to learn how to set up programs on.
I've been playing with Mala for a couple hours (mostly setting up my own layout).  When launching a game, I found that I get the Command Prompt window on top of Mala and Mala's "starting" window.
This takes away a lot from the look of the front end and makes it look, well, like Windows.
Was wondering if there was an easy way to hide the command prompt window?
Any help would be greatly appreciated.
Thanks in advance,
Jeff
« Last Edit: December 15, 2006, 02:57:11 pm by hsr »
Jeff
hsr
Re: Question on Mala When Launching a Game
« Reply #1 on: December 15, 2006, 02:36:59 pm »
Forget it.  windowstate=0 in mala.ini
Jeff
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #2 on: December 15, 2006, 03:43:36 pm »
Cool.. You worked it out.
Just FYI it is set like that by default so you can fault find any Mame errors when you first set it up.
You can change all settings via the Gui. No need to edit mala.ini
See Pic...
http://mala.arcadezentrum.com/help.html#faq13
