Author Topic: Xbox to LCD PSone display... how?  (Read 2530 times)
xed_it2002
  • Last login:March 30, 2003, 08:10:21 am
« on: March 30, 2003, 08:22:33 am »
Hello,
I want connect my Xbox console to LCD Psone display but in RGB... i have connect this display in composite and the result is too poor... the image is affect by interference and the brightness is too up.
The Sony LCD display can be connected in RGB but when i have tried the display was black... why?
I have buy 2 cable. the fist cable is PS->Scart(RGB) and the second cable is Xbox to scart (RGB). I have build an adapter to connect this cable and i have cut all the resistence from the cable... but non work..
May the xbox cable must be mod to switch in RGB manually?
Please help me!!
How i Can?
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Xbox to LCD PSone display... how?
« Reply #1 on: March 30, 2003, 01:29:41 pm »
So what do you mean when you say you cut all resistance?  The scart cable should have the proper pins grounded to put the av port into RGB mode. Look here to verify which pins are grounded http://www.gamesx.com/avpinouts/xbox.htm
xed_it2002
« Reply #2 on: March 30, 2003, 07:51:05 pm »
i have cut the condenser that are in the psone-scart cable...
Dave_K.
    • Arcade Fever
« Reply #3 on: March 30, 2003, 10:29:40 pm »
I'm sorry but I have no idea what you are talking about with this "condenser"...and why you are bothering with a psone scart cable if the point is hooking up this lcd to an xbox.
Now I'm also assuming you know what you are talking about when you say the LCD screen can indeed be take 15khz RGB input (all the ones I've seen only work off composite video input).  But if this is the case, then all you do is connect the xbox scart R/G/B/sync/gnd to the lcd RGB inputs.
android
  • Last login:August 21, 2006, 09:44:47 am
« Reply #4 on: March 31, 2003, 11:21:47 am »
Probably he means capacitor...
xed_it2002
« Reply #5 on: April 02, 2003, 04:57:42 pm »
YES!! I want say capacitor!!!
The PSone LCD monitor work in RGB to PSone and PS2 but i have connect R/G/B/sync/grn but the monitor get only Composite input... why don't switch to RGB?
Dave_K.
    • Arcade Fever
« Reply #6 on: April 03, 2003, 12:36:26 am »
I think you are highly confused.  The LCD takes composite in only.  If you are using a SCART cable from the PSOne or PS2 to the LCD screen, its probably just using the composite video pin.
Sorry.
