Author Topic: Help with Credit Board to I-PAC connection??  (Read 1287 times)
lettuce
  • Make It So!
« on: December 11, 2006, 06:14:05 pm »
Hava a SOLO Credit board that is connected to a MARS Coin Mech. On the credit board there are various screw terminal block, 1 of these block terminals is for 'Coin Switch' which has 3 inputs which are:
Coin Switch N/C
Coin Switch N/O
Coin Switch Common
Which one of these connections should i connect to the I-PAC 'Coin' Input???
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
Re: Help with Credit Board to I-PAC connection??
« Reply #1 on: December 11, 2006, 06:29:36 pm »
Ground and N/O should do the trick for you.
www.wolfelectronics.ca
Cap Kits for Canadians!
lettuce
  • Make It So!
« Reply #2 on: December 12, 2006, 12:19:47 pm »
Common is ground, right?? So connect N/O to 'Coin' input on the I-Pac and Common to 'Ground' input on the I-Pac?? Am i right in thinking that the I-Pac can take up to 5 volts?? I cant see anywhere on the Credit Board diagram that says if these Coin switch terminals carry a electrical current or not!, do they usually?
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« Reply #3 on: December 12, 2006, 04:45:55 pm »
Grauwulf is right.  Common is your ground.  And your switch will be normally open (NO).  Once it closes the switch(NC)  (AKA the credit in the machine it will activate).
Peace!
rdowdy95
lettuce
  • Make It So!
« Reply #4 on: December 12, 2006, 06:27:46 pm »
So i dont need the N/C terminal connected to the I-Pac then?
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
« Reply #5 on: December 13, 2006, 01:00:25 pm »
no, no need to connect the N/C connection.
