Author Topic: How hard would it be to vectorize this logo?  (Read 2139 times)
lustreking
  • Last login:October 11, 2021, 08:43:06 am
  • One Louder
« on: December 11, 2006, 04:36:08 pm »
This isn't arcade related, it's actually a label for my homebrew.
I haven't used Illustrator before, so I'd like input on if I should attempt this myself, or get someone else to do it.
thanks,
-S
FunWithFire
  • Last login:July 07, 2009, 01:17:30 am
Re: How hard would it be to vectorize this logo?
« Reply #1 on: December 11, 2006, 07:13:06 pm »
Having not used Illustrator before might make it worse then it should be, but that image could be vectorized fairly easily. The monkey looks as if it was vector at one point.
Mista-FraggadeliX
  • Last login:January 07, 2008, 11:34:42 am
  • Whether you think you can or you cant,you're right
« Reply #2 on: December 12, 2006, 06:55:22 am »
This should be really easy with Adobe illustrator CS2 and if you have a decent resolution on that logo...
AI-CS2 has a function called 'Live Trace' which really does all the work for you...
Offcourse, if you need absolutely perfect vectors (for a less illustrative logo or a line of type) you're always better of doing it yourself...
zorg
« Reply #3 on: December 12, 2006, 08:18:28 am »
please DON'T USE automatic tracing tools.
I'm on the planning stage
  • Last login:February 09, 2026, 10:26:35 am
« Reply #4 on: December 12, 2006, 02:26:00 pm »
Yeah, they usually have hideous results.  That being said, that should not be hard to do by hand at all.
