Author Topic: 7 button layout opinions needed.  (Read 1800 times)
2slk
  • Last login:February 27, 2004, 11:38:09 pm
  • Fascinating, Captain.
« on: March 29, 2003, 04:10:29 pm »
Hey folks. Almost ready to wire my CP.
 123
 456
7
or
 123
 456
1
 Still can't decide. Comments? Opinions? Thanks!!!
SirPoonga
  • Puck'em Up
  • Last login:July 20, 2025, 03:37:24 pm
  • The Bears Still Suck!
Re:7 button layout opinions needed.
« Reply #1 on: March 29, 2003, 04:17:03 pm »
how about using the ctrlr files
Then wire it like
  123
7456
then in the ctrlr folders make a neogeo.ini remap the controls do it is like
  567
1234
2slk
« Reply #2 on: March 29, 2003, 10:26:22 pm »
SirPoonga,
 Thanks for the reply. I've looked into this a little because I'm not really familiar with the ctrlr ini files. If my understanding is correct, I have to create a new ctrlr file with the neogeo.ini remap. Then, I set up my FE with a command line option to run all neogeo games using that ctrlr file. Am I correct? Thanks again..........
SirPoonga
  • Puck'em Up
« Reply #3 on: March 30, 2003, 12:01:53 am »
Yeah, basically.
You make a folder in the ctrlr folde (for example MyArcade)
Then you setup a default.ini file witht he defaul setup.
Then a neogeo.ini file with the neogeo setup.
All controls you can use in the ini files you will see in the std.ini file.
Then either edit the mame.ini file or run mame like:
mame -ctrlr MyArcade mslug
