Author Topic: diehard - needs to have "-bios us" flag to make it run ? How To ?  (Read 10927 times)
mrclean
    • Guscade
 ??? The default BIOS of the Sega ST-V system is Japanese, because most of the games on that system were primarily for the Japanese market. However, Die Hard Arcade only runs with the US version of the BIOS. You can select it with the -bios parameter as follows:
   mame diehard -bios us
how do i add this ?
2,370,650 Gun.Smoke
cdbrown
  • Bowowow
Re: diehard - needs to have "-bios us" flag to make it run ? How To ?
« Reply #1 on: December 07, 2006, 06:30:02 am »
Easiest way is to do that from a command prompt
mrclean
    • Guscade
« Reply #2 on: December 07, 2006, 11:33:56 am »
is there any other way to do this from the ini file ? because im having trouble with the dos prompt keeps telling me it cant find the path, in my ini file it says bios default, but i dont want it to mess with other games i just wanna fix diehard
2,370,650 Gun.Smoke
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: December 07, 2006, 02:01:12 pm »
Make a file diehard.ini, and in it put "bios us".  That's it.
I'd put the file in the "ini" folder, but this working assumes the following two defaults in standard mame.ini:
inipath                   .;ini
readconfig                1
More info in the mame/docs/windows.txt file.
Robin
Knowledge is Power
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
« Reply #4 on: December 07, 2006, 02:34:36 pm »
I wish my machine was fast enough to play DHA at full speed. Savages.... Damn polygon games
GT
mrclean
    • Guscade
« Reply #5 on: December 08, 2006, 08:54:09 am »
inipath                   .;ini
readconfig                1
that totally worked! thanks.. however i just want to make sure that this won't mess up other games i.e. japanese games that require jap bios?! or is it only going to effect that one game ? Any ways
GT
Your right about the speed its slugish to say the least maybe one day it will be running faster... looks promising. Excited for Dragon's Lair on the way!
2,370,650 Gun.Smoke
cdbrown
  • Bowowow
« Reply #6 on: December 08, 2006, 10:08:56 am »
As you've only applied it to the diehard.ini then tha'ts all it will apply to.
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« Reply #7 on: January 11, 2009, 09:47:23 pm »
Is there any way to speed up this game? it plays a little bit off the pace for my liking
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: January 12, 2009, 03:10:49 pm »
Since this was bumped, I might as well post it now.  Looks like mame now has a way for the diehard driver to set the us bios.  Hasn't been done yet (0.129), but I'll bet before 0.130 comes out it will have it, which will mean no diehard.ini with just the one bios line in the near future.
What mame number, CPU, and OS (32 vs 64 bit) are you using?  Looks like 0.128u4 had a major slow down for stv.c games (diehard).  (I'm going by vfkids, another stv game.)  64 bit OS and mame helps a lot over 32 bit, but if your OS isn't 64 bit, no help there without installing new OS.  Also, check the benchmarks and if your computer is less than the ones that run vfkids at 100%, very little to do. :(
Robin
Knowledge is Power
