Author Topic: Mala and screen rotation?  (Read 3442 times)
Dave Wave
  • Last login:January 13, 2019, 08:29:38 am
« on: December 05, 2006, 02:06:30 pm »
I have a rotating monitor in my cab and  want to configure Mala with both a horizontal and vertical menu. However when use the vertical config, all of the text is running vertical (not horizontal) ie the text is not changing orientation and is not positioned where I had set it in the layout. Mala is configured for the vertical mode and when it launches, the logo and background are oriented correctly, but the text is running vertical. Any ideas?
loadman
  • Moderator
    • MaLa
Re: Mala and screen rotation?
« Reply #1 on: December 06, 2006, 08:23:54 pm »
How Bizzare ???
Can you e-mail me your layout files?  I will PM you
loadman
  • Moderator
    • MaLa
« Reply #2 on: December 10, 2006, 01:12:39 am »
It looked like you were trying to make a vertical setup using part of a Horizontal base somehow?
The layout file was a bit of a mess for some reason.  :dunno
So rather than try and repair it (as you said it was unfinished anyway) .....
.....The fast fix was to start a new layout, switch it to vertical mode (see attached pic) and then add your background pic etc..
have fun  ;D
« Last Edit: December 10, 2006, 01:20:55 am by loadman »
Dave Wave
« Reply #3 on: December 11, 2006, 03:11:45 pm »
Loadman,
That did the trick...thanks for the help. I guess something must have been corrupted in all of my edits and saves.
Thanks again,
-Dave
loadman
  • Moderator
    • MaLa
« Reply #4 on: December 11, 2006, 04:43:32 pm »
Loadman,
Thanks again,
-Dave
Yeah
I could not re-create the problem..  Weird-o-rama  :P
