Author Topic: Marquee flourescent light. How?  (Read 3134 times)
Justin
  • Last login:November 25, 2025, 10:20:05 pm
    • Centipede MAME cabinet
« on: March 28, 2003, 07:12:39 pm »
My Centipede Cab came with the fluorescent light assembly installed (no tube though).  A sticker says it is a 120V lamp.
Since I will no longer be using the original power supply, how on earth do I power this lamp up?  Do I need a transformer of sorts?  Al I seem to have right are a few cables dangling out of the assembly.
Thanks for any help guys.
"3 warps to Uranus" -- so I stopped playing!
aj6500
  • Last login:July 29, 2003, 06:17:31 am
  • Does this rash look contagious?
Re:Marquee flourescent light. How?
« Reply #1 on: March 28, 2003, 07:52:29 pm »
Walmart sells fluorescent assemblies for <$15 including bulb.  Just plug it in to your power strip.
They say patience is a virtue, and ignorance is bliss.  So I guess you can have a pretty good life if you're stupid and don't mind waiting around.
SNAAAKE
  • -Banned-
« Reply #2 on: March 28, 2003, 08:02:29 pm »
Or home depot half that..
Only $6.99 with bulb.
aj6500
« Reply #3 on: March 28, 2003, 08:22:14 pm »
You have thwarted my evil Walmart based plans for the last time Snaaaake.  The next time we meet on the field of battle....
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #4 on: March 28, 2003, 08:51:54 pm »
:D ;)
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #5 on: March 28, 2003, 09:44:14 pm »
You know it's funny... I often say something similiar in my head whenever I hear of snaaakes mis-adventures =P but I never post it as he usually doesn't get/appreciate my unique brand of humor =P
*Shrug*
rampy
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #6 on: March 28, 2003, 10:16:45 pm »
I replaced the ones in my cab with $7 home depot ones.  One I had to mount in a different position than normal.  I screwed the screws right through the plastic sides to get it mounted the way I wanted.
Justin
« Reply #7 on: March 28, 2003, 10:24:24 pm »
So, MUST I discard the existing one?  >:(   Looks like new!
_Iz-
  • Last login:December 03, 2025, 11:55:42 pm
  • Time to coin up!
« Reply #8 on: March 29, 2003, 01:25:16 am »
Don't need to discard it. I had the same situation with mine. Stripped cab, no power supply or wiring but original fixture was there. I bit the bullet, wired an extension cord with the end snipped off to it and tried it with straight 110v from the wall. Plugged it in and ran for cover! Worked perfectly! Whew!!
« Last Edit: March 29, 2003, 01:26:45 am by _Iz- »
SNAAAKE
  • -Banned-
« Reply #9 on: March 29, 2003, 01:38:41 am »
OHH ! NOO ! :D
*Shrug*
rampy
Humor is always cool but at times they are little harsh.
I honestly DO get your jokes but you know...all the time is not funny.
Like spelling jokes or grammer jokes arent funny !  :(
Most of the time its just typing error.. :-\.
« Last Edit: March 29, 2003, 01:55:38 am by SNAAAKE »
kspiff
  • Last login:February 02, 2016, 09:15:36 pm
  • Love of the game, baby.. love of the game..
« Reply #10 on: March 29, 2003, 02:19:49 am »
The marquee lights run off normal 110V AC power not DC, so Iz is right.. no real need to replace it.. you can verify this by checking to see if the old light wires directly into the AC filter/transformer (no good with the technical terminology, sorry if I'm wrong on names here) or the DC power supply.
k-spiff
Justin
« Reply #11 on: March 29, 2003, 08:34:20 am »
OK, so let's say I wire it up to a regular power cord.
I still see 5 cables coming from the assembly.  2 or 3 cables I can deal with, but 5?   hehehe
I think I need a wiring diagram  :(
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #12 on: March 29, 2003, 10:19:48 am »
Not having seen your light, I would assume that the extra two are for a switch to power it on and off?
