Author Topic: New Product: TurboTwist 2 - The Ultimate Spinner / Paddle control ! From GGG!  (Read 121154 times)
PoDunkMoFo
  • Last login:January 09, 2025, 07:20:35 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
Re: New Product: TurboTwist 2 - The Ultimate Spinner / Paddle control ! From GGG!
« Reply #240 on: December 15, 2006, 06:58:03 pm »
O.K. Not that Im' a fan but......
Looks like nothing gets done at work today.
PoDunkMoFo
    • Visual Horizons
« Reply #241 on: December 15, 2006, 06:58:39 pm »
Ooops double post
« Last Edit: December 15, 2006, 07:00:41 pm by PoDunkMoFo »
tetsu96
  • Last login:September 06, 2024, 12:00:03 pm
  • MAME On...
    • My Old Cabinet / MAME32 build site
« Reply #242 on: December 15, 2006, 07:18:11 pm »
That's certainly a nice looking piece of equipment.  Give a shout on the thread if we should wait until you update the ordering page for the token knobs or if we should just go ahead and order away.  I'm already sold on it.
Encryptor
  • Trade Count: (+34)
« Reply #243 on: December 15, 2006, 11:26:00 pm »
Randy,
There is someone here that sells vinyl labels. His name is MikeDeuce. He also sells the clear discs pictured below. They are made to go inside a standard happs button. I'm not sure what size they are but if this is something like you are looking for earlier in this thread as a clear dome maybe you can ask him where he gets the ones he sells. Just a thought.
Encryptor
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #244 on: December 15, 2006, 11:27:54 pm »
I'd be willing to bet those discs come from Tap Plastics.  They don't come in .984, though.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:July 14, 2025, 03:43:29 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #245 on: December 16, 2006, 12:06:27 pm »
As you scour the web you should know that .984" = 25mm. Does Tap have 25mm discs?
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #246 on: December 16, 2006, 12:21:56 pm »
I can machine 0.984 discs from clear acrylic but the surface would be perfectly flat, not domed like the cast discs. I could make them thinner than the ones TAP sells though.
I'll check what thicknesses I've got lying around on Monday.
Kremmit
  • - AHOTW -
« Reply #247 on: December 16, 2006, 08:38:21 pm »
As you scour the web you should know that you can check at www.tapplastics.com:P
(And no, they don't- standard imperial sizes only.  Too bad, the cabochons might be just what we're looking for.  Wonder if they can do a special run?)
RandyT
    • GroovyGameGear.com
« Reply #248 on: December 16, 2006, 11:16:33 pm »
Thanks for all of the suggestions.  I have all the equipment for doming the decals on order.
I also have 3 vinyl cutters, one of which is over 50" and prints as well, and a 36" art reproduction quality inkjet.  So I have the "medium" end pretty well covered  ;)
The discs are an interesting find, but I don't think they will compare to domed ones.  Give me until after Christmas, and I expect there will be plenty of options for decorating the spinner tops.
RandyT
« Last Edit: December 17, 2006, 12:31:38 pm by RandyT »
RandyT
« Reply #249 on: December 17, 2006, 02:16:27 am »
For those who have been waiting, the TokenTop™ knobs are now available at the store.
Linkage
RandyT
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #250 on: December 17, 2006, 08:38:58 am »
Randy,  Just a marketing suggestion, I found that sometimes people were hesitant to buy tokens because the photographs and bling didn't give a good feeling of what the tokens actually looked like.  You might have the same problem.  I comissioned Markrvp to do some professional photos of the tokens for me, and they came out great. You might want to provide a 'token detail' photo for reference.  You can steal this one if you like.
I know most all BYOACers are familiar with the 2004 tokens by now, but any n00bs that visit your site might have this problem.
Also, how easy is it to replace the tokens?  Should I expect a zillion requests for single tokens now?  :)
(Oh, and check your PM.)
« Last Edit: December 17, 2006, 07:53:19 pm by Santoro »
Donkey_Kong
    • CNC Machines
« Reply #251 on: December 17, 2006, 11:56:44 am »
Linkage
RandyT
Ok Randy...they look sweet!! Order #3093 please add The Blk Knob W/ Nickel option...THXS!!
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
« Reply #252 on: December 17, 2006, 12:08:29 pm »
Randy - you have been a busy little elf.  :applaud:
JoyMonkey
    • JoyMonkey.com
« Reply #253 on: December 17, 2006, 01:45:33 pm »
One question; how easy is it to pop out the token and put in another one?
tetsu96
  • MAME On...
« Reply #254 on: December 17, 2006, 10:28:54 pm »
Heh - just ordered the spinner and knob w/ the Brass token, but the Nickel token looks awfully classy too...  should have an option to include both tokens w/ the spinner (or do you epoxy / etc the things in there?).  I wouldn't be upset if a spare Nickel token fell into order #3098 right before you boxed it up, but I'm sure they'll both look good on a live cabinet.
Looking forward to it Randy.
RandyT
« Reply #255 on: December 18, 2006, 10:03:48 pm »
Not.  If you think this would be desirable, make sure you request that the token be included loosely so you can use your own methods for keeping it in the knob.  I use a pencil eraser sized spot of superglue gel.  It could probably be removed by putting the knob in the freezer overnight and then blasting the center of the token with a torch.  Should flex the metal enough to pop it loose, but I'm not trying it.  :)
RandyT
JoyMonkey
    • JoyMonkey.com
« Reply #256 on: December 19, 2006, 06:49:01 am »
Good to know. I think I'll order a naked knob (forgive the pun) and use a small dab of silicone to keep a token on there.
Derrick Renaud
  • Last login:December 06, 2024, 04:31:44 pm
« Reply #257 on: December 19, 2006, 05:58:59 pm »
Randy,
When not using your Opti-Wiz based board, can the Red/Black wires be directly connected to 5V?  Or do they need a resistor in-line.
I am assuming no.  That there already is a resistor in the spinner housing.
Thanks,
D.
RandyT
« Reply #258 on: December 19, 2006, 10:27:36 pm »
You assume correctly.  They can be connected directly to 5v.
RandyT
Donkey_Kong
    • CNC Machines
« Reply #259 on: December 22, 2006, 01:47:37 pm »
Santa came early...looks like someone was a good boy this year!
Arrival was QUICK and contents all accounted for perfectly. Special requests...umm yep! Now if they could just magically mount themselves to my un-built CP...
Thanks GGG...Merry X-mas to ALL!!
Dang do you SEE  :o that BYOAC token...inside of that knob!
That is 'HIGH CLASS' my friend. I'm truly... :notworthy: But what the heck eh.
« Last Edit: December 22, 2006, 03:49:23 pm by Donkey_Kong »
JoyMonkey
    • JoyMonkey.com
« Reply #260 on: December 22, 2006, 03:43:59 pm »
Mine arrived safely today too! Going to give it a quick try in my test CP now...
FrizzleFried
    • Idaho Garagecade
« Reply #261 on: December 22, 2006, 04:18:38 pm »
I am VERY interested in how the knobs "Accu-Twist™" feature works...
tranq
  • - Banned -
  • Last login:January 11, 2007, 05:04:35 pm
  • - Banned -
« Reply #262 on: December 22, 2006, 04:20:39 pm »
Mmmm, that looks nice.  As for mounting the coin, you know those sticky gels they use to keep laminated pamphlets together?  They're pretty sticky, and considering there won't be any sideways force on it, it shouldn't move....wait! - maybe a magnet underneath?
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #263 on: December 22, 2006, 09:01:37 pm »
I don't think Brass is magnetic. (the nickel tokens are nickel plated brass.)
mrbones
  • Last login:September 19, 2024, 12:25:11 pm
    • ATVFlorida.com
« Reply #264 on: January 20, 2007, 10:59:06 am »
Can the Turbotwist 2 be plugged into a Minipac from Ultimarc? Maybe the slave version, perhaps? I ask because I already have the Minipac and don't need another interface board.
FrizzleFried
    • Idaho Garagecade
« Reply #265 on: January 20, 2007, 12:31:07 pm »
Is anyone else having problems with their TT2 coming loose?  I have really cranked down with a button wrench (requiring me to remove the weight to do so)...and again,  I found my TT2 starting to loosen up last night.   Standard 3/4" wood CP... not sure whats up.   I may try a different "nut" this time.
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
I havn't used mine yet since my cocktail table isn't done but I think you could always use a little locktite on the threads.
I b**ch. People listen!!
FrizzleFried
    • Idaho Garagecade
« Reply #267 on: January 20, 2007, 12:47:05 pm »
Yah...locktite is looking more and more appealing.  I really screwed it on bigtime this time...we will see if it loosens up...
squirrellydw
« Reply #268 on: January 20, 2007, 02:05:12 pm »
Just remember to use the BLUE Locktite and NOT the RED.  I think the RED is permanent.
RandyT
« Reply #269 on: January 20, 2007, 05:04:41 pm »
Is this from use with the steering wheel or just the standard knob?
The hole in your panel may be a little too sloppy and allow the spinner body to shift laterally and cause the nut to loosen.  If this is the case, you can wrap a few layers of electrical tape around the body of the spinner so it better fits the hole in your panel.  If it can't shift, there's no way for it to loosen.
Also make sure you don't twist the nut down too tight.  It's possible that it was torqued so tightly that the nut expanded to the point where it almost popped to the next thread, and finally did so over time.  If you think this might be the problem, and you'll know if it does it again, you might want to use a new nut and just snug it the next time.
I can't say what could have caused it without being there, but these are a couple of things for you to consider.
RandyT
mrbones
    • ATVFlorida.com
« Reply #270 on: January 21, 2007, 09:54:34 am »
RandyT
« Reply #271 on: January 21, 2007, 12:06:10 pm »
Sorry, I don't own one and therefore cannot test this combination.  It should physically work, but I can't make any promises about performance or other possible issues one might have.
RandyT
FrizzleFried
    • Idaho Garagecade
« Reply #272 on: January 21, 2007, 12:50:47 pm »
My hole was cut with a 1.125" hole saw...but perhaps there is a little play in there a bit...if it comes lose again I will try the tape route... I am using the spinner as a spinner.    Just "big blue" attached and the weight of course.
Since the last "crank down" I have yet to feel any movement...
Thanks Randy...
Donkey_Kong
    • CNC Machines
« Reply #273 on: January 24, 2007, 12:27:35 am »
Hi all-
If you have contemplated this product for whatever reason...MAYBE my review could help you decide. MAYBE!!
DONKEY KONG'S REVIEW of the TT2...Enter at your own risk!!
http://forum.arcadecontrols.com/index.php?topic=62443.msg620104#msg620104
« Last Edit: January 24, 2007, 12:30:24 am by Donkey_Kong »
rubberpoultry
  • Last login:January 05, 2014, 09:32:36 pm
Is the steering wheel still available? I couldn't find it on the site.
Kaytrim
  • I'm too nice a guy
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #276 on: February 09, 2007, 10:33:47 am »
Is it any reseller in EU who have this spinner, so I can avoid to pay a roughly high toll in Denmark (EU) (40% to total price+11$ fee)? I hope arcadeshop.de or such in the  future add GGG as a vendor.
This is the only reason why I diddent order yet.
So Randy, I hope you start a business in EU (like in UK).
Level42
« Reply #277 on: February 09, 2007, 10:59:38 am »
Maybe you can have it sent as a gift.......just an idea ;)
squirrellydw
« Reply #278 on: February 26, 2007, 04:15:34 pm »
 :notworthy:
« Last Edit: February 27, 2007, 11:38:51 am by squirrellydw »
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #279 on: February 27, 2007, 07:57:52 pm »
Does the spinner perform EXACTLY the same (IOW with the same resolution/update speed) on the Z-axis as it does on the X or Y?
I tested it a bit (in USB mode) with Tempest and found that I need to cut the sensitivity down to 3% to match the 6% used when on the X-axis.  This would seem to imply that something is different with the Z-axis and the TT2 (or opti-wiz).  Maybe the scaling is different?  Is there any difference (regarding Z-axis performance) between PS/2 and USB modes?
Of course, the reason for the Z-axis is the ability to add a trackball to the opti-wiz.  If the spinner works on the Z-axis 100% as good as it does on the X-axis, then that certainly adds value to the TT2.
If I do not respond to your post in a timely manner, feel free to PM me.
