Author Topic: Defender/Stargate PSU  (Read 1939 times)
spacies
« on: November 22, 2006, 03:42:21 pm »
Hi,
Does anyone have info on converting a Defender/Stargate to use a switchmode PSU?
Any links or info appreciated.
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
Re: Defender/Stargate PSU
« Reply #1 on: November 22, 2006, 06:20:55 pm »
Here is a pretty good place to go for Williams stuff.  Requires a little read but it is complete.
http://www.robotron-2084.co.uk/techwilliams2jamma.html#power
Happy Gaming!
spacies
« Reply #2 on: November 22, 2006, 08:43:40 pm »
Thanks,
Does it require a battery change to use a switcher? I read somewhere about changing to lithium batteries?
What about the -12V from the original loom?
Switchers don't have those.
RetroACTIVE
  • Gramps
« Reply #3 on: November 22, 2006, 09:30:26 pm »
Nope... the battery is for CMOS memory retention when power is off.  Its a separate circuit all together.  Changing the batteries to lithium is a good thing to do anyway.
Some switchers do have -12V... usually ones that are > 150W.  But I don't think its a problem
This is what it said @ http://www.robotron-2084.co.uk/techwilliams2jamma.html#power
"The Sound board requires +12v unregulated, -12v unregulated and ground. The +12v and -12v are rectified on the sound board to produce its own regulated +5v supply. If you use -5v and +12v from the JAMMA PSU it will work fine."
Happy Gaming!
