Author Topic: Refinishing gurus; how clean does the wood need to be?  (Read 4223 times)
ASmig
  • Last login:November 22, 2006, 09:23:01 pm
« on: November 21, 2006, 05:22:12 pm »
See pic attached, is this ok to bodo and prime or does the cab need to be perfectly clean to do the job right?
Re: Refinishing gurus; how clean does the wood need to be?
« Reply #1 on: November 22, 2006, 12:35:30 pm »
Primer will cover that so long as it is smooth.  Being "clean" is really an issue more for stains.
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
« Reply #2 on: November 22, 2006, 09:38:24 pm »
I'd recommend KILZ primer and using a tack cloth for dust removal.
The primer will only be as smooth as whats under it.
Will you be going to a dark color or light?
Tinting the primer will help with cover a color that bleeds thru the paint.
Cheers
There are three kinds of people in the world those that can count and those that can't.
« Reply #3 on: November 23, 2006, 11:25:43 am »
Especially yellow.  Yellow is hell if you don't tint the primer.
prOk
  • Last login:December 28, 2015, 08:29:34 pm
  • www.rgvac.com
    • Brian's Classic Arcade
« Reply #4 on: November 24, 2006, 08:08:57 pm »
I choose to use a high build automotive primer.. a couple coats sanded in between and you can get a glassy surface.. you can't really sand killz so I don't use it.   Priming is a must though.
johnvv
  • Last login:June 19, 2012, 08:36:20 pm
« Reply #5 on: November 24, 2006, 09:03:44 pm »
prOk:
Can you clarify some 'best practices' for using auto primer for others?  Is the product you use applied via a spray gun only?  Or does it come in a spray can or regular can as Killz and Zinsser do, thereby making it easy to apply for the casual restorer?  Does the auto primer use a bonding agent?  What brand(s) do you recommend?
I've had a couple cabinets done with auto primer and agree that it makes a great surface for painting as it sands soooo smooth.
