Author Topic: ti4200 TV-Out causing big performance hit  (Read 2011 times)
brianoneill
  • Last login:January 27, 2017, 04:44:59 pm
« on: March 27, 2003, 05:51:53 pm »
Hi,
I'm building a cabinet and have decided to put a TV in rather than a monitor.
I've got Gainward ti4200 128ram with vivo card on an athlon 2200 pc.
I am using 'TV Tool' to display windows/mame on my 25" SANYO TV.
It all looks fairly well...although I can only select between 2 resolutions but the big problem is that games that run on my monitor at 60/60 fps, now run around 45/60 fps.
Is this normal while using tv-out ? Anything I can do tho fix/improve it ?
Regards,
Brian.
BobA
  • What Me Worry?
Re:ti4200 TV-Out causing big performance hit
« Reply #1 on: March 27, 2003, 08:12:48 pm »
Check to see if a more current driver is available for your card.  Some drivers have not been optimized as well as those from other manufacturers and and update will sometimes help.
BobA
brianoneill
« Reply #2 on: March 29, 2003, 09:51:27 am »
thanks.
after much messing around with drivers and MAME, itf finally working pretty well :)
