Author Topic: J-stik shaft diameter  (Read 2333 times)
ddoyle1996
  • Last login:July 18, 2003, 04:00:31 pm
« on: March 27, 2003, 03:56:35 pm »
Can anybody with a J-stik tell me what the diameter of the shaft is?  I'm thinking about using one of those to make a removable flight stick (using the standard Raider pro hack), and I need to know if I can use it with the Raider pro stick.
RoadhawK
  • Last login:May 29, 2023, 02:15:28 pm
  • Arcade Junkie :)
Re:J-stik shaft diameter
« Reply #1 on: March 27, 2003, 04:56:41 pm »
ANDEEEEEEEEEEEE! :p
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
« Reply #2 on: March 28, 2003, 03:29:20 am »
I also would like to know if I can do a standard Raider Pro hack with a J-Stick or T-Stick as I would like to make my Tron stick change from 8-way for Discs of Tron to 4-way for Tron.
ddoyle1996
« Reply #3 on: April 01, 2003, 09:12:59 am »
This is what I'm planning.  Hobby Lobby sells aluminum tubes up to 9/32" diameters.  The tubes are soft and can easily bend, but the 1/4" tube fits inside the 9/32" tube very tightly.  This gives me a pretty strong tube.  It may be strong enough, but just to be safe I also plan on putting at least one more tube (a 7/32" tube) inside the 1/4" tube.  Two tubes placed inside a third should be plenty strong.
The reason I am doing this is because no one else around here sells aluminum tubes.  I like the 9/32" tube because the small plastic piece that comes out the bottom of the Raider Pro flight stick looks like it has a 9/32" hole in it.  This means I can simply epoxy the tube into that hole.  I also like the fact that the tube is hollow so you can run wires through it.
The only downside is the remaining parts of the e-stik that normally go on the shaft have bigger holes in them than the 9/32" shaft.  I'm sure this could be fixed by placing tape around the 9/32" tube where those parts normally would be.
radiator
  • Last login:April 18, 2013, 07:14:43 pm
  • SFA OK!
    • :: verticalcircle ::
« Reply #4 on: April 01, 2003, 03:20:37 pm »
j-stick shaft diam. approx 0.9cm (or just under 3/8 of an inch)
*m
When the Germans bombed the British, the British ducked.
When the British bombed the Germans, the Germans ducked.
When the Americans started bombing, everyone ducked!
RetroBorg
« Reply #5 on: April 02, 2003, 05:15:58 pm »
I will definately be trying the raider pro hack with an E-stick.
8-way Discs of Tron, 4-way Tron, way to go!
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #6 on: April 03, 2003, 12:50:47 am »
The Tron stick has been talked about before.  Isn't it an 8 way stick?  I seem to remember one of the big dogs on this board taking apart his Tron stick to explain how it was build.
This opinion was created from 100% post consumed information.
RetroBorg
« Reply #7 on: April 03, 2003, 05:32:00 am »
Perhaps that might be right but I thought you needed a 4-way joystick for Tron especially during the light-cycles. Can anyone else shed some light on this?
kspiff
  • Last login:February 02, 2016, 09:15:36 pm
  • Love of the game, baby.. love of the game..
« Reply #8 on: April 03, 2003, 05:42:08 am »
I think it was an 8-way trigger stick with a diamond shaped actuator.. that way the primary directions are defined and the corners are available but less reliable and with a smaller 'sweet spot.'
I would just use the J-stick anyways.. short of buying real Tron sticks you'll find yourself out of luck, otherwise (and, hey, why not set up dual Js in 4-way for some Assault action? ;D).
k-spiff
RetroBorg
« Reply #9 on: April 03, 2003, 07:35:12 am »
You most certainly love your Assualt kspiff, I played it the other day for the first time, not a bad game at all, but I need to try it with 2 x 4-ways.
kspiff
« Reply #10 on: April 03, 2003, 08:06:26 am »
Yes, Assault is one of my favs.. Namco just has a way with their games (I would say they can do no wrong, except for that whole Hometek division :P).
I'm making some Raider Pro dual sticks, myself.. too bad I'll likely need to waste a set of Competitions to do it..
I remember when I first got my HotRod and was so excited to try my hand at some arcade authentic Assault..
I'll just give you a minute for that to sink in.. ::)
Let's just say my keyboard smells like feet now.
k-spiff
OSCAR
    • Oscar Controls
« Reply #11 on: April 03, 2003, 08:41:30 am »
See this thread:  http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=44;start=0
I took apart a Tron joystick and measured the bottom actuator & restrictor.  In a later thread, someone else posted that there is an upper restrictor, too, but on the joystick I had the upper one was so beat up the joystick didn't even contact it.
ddoyle1996
« Reply #12 on: April 03, 2003, 09:33:26 am »
It's done.  I used 4 aluminum tubes (3/16", 7/32", 1/4", 9/32") and put them one inside the other.  I used 4 because I have kids and knew it'd get beat up.  I tried bending this myself and couldn't do it.  I'm pretty sure the flight stick would break before the shaft bends.
The tutorial at mamecheats.fateback.com/tutorial.htm shows how to cut the plastic piece coming out the bottom of the Raider Pro so you can insert a new shaft into it, but I did not do that.  The 9/32" tube fit perfectly in the part of the plastic piece that this tutorial shows you cutting off.  Instead, I just used some epoxy to cement the tube in that piece.  I used the dremel to cut the tube to length.
The mamecheats tutorial uses a plastic stopper to control how high the flight stick sits on the control panel.  I used a rubber grommet instead.  The rubber grommet works just as well, and it actually does a pretty good job at keeping the joystick from rotating.  I used the epoxy to cement it at the right position on the tube.
After that, I used the dremel to create a grove in the tube where the e-clip needed to be.  I put the remaining pieces of the e-stik (spring and 2 plastic pieces) on the shaft and clipped the e-clip on and OH YEAH!  I've got a Raider Pro flight stick on an e-stik base.  I can switch from 4-way to 8-way easily, and the wires for the flight stick come out the bottom of the tube since it's hollow.  Now I just have to finish the rest of my cab so I can use it.
RetroBorg
« Reply #13 on: April 03, 2003, 05:07:09 pm »
Thanks Oscar, super helpful as always.
Good work ddoyle1996 you will have to let us know what your joystick plays like once you have finished your cab.
